Advanced Cluster Part 3
• In partthe 3“Custom_Gauge”, add new “StackLayout” and name it “StackLayout_Texts”
• Add 2 “Text” controls and 1 “Text Value” control to the “StackLayout_Texts”, rename the text controls to “Text_Top” and “Text_Bottom”
• Ensure that the order of the items inside of this Bestlayout Practiceis the Custom_Gaugesame controlas willshown in the picture above.
• Set these parameters: Arrangement = Vertical, MinimumSize = 250, VerticalAlignment = VCenter
• Set these “Text_Top” values: VerticalAlignment = VCenter, HorizontalAlignment = HCenter, Text Alignment = Center, Text Style = OpenSans35, Text = “RPM”
• Same for the “Text_Bottom” values, but set Text = “” (to be further customized adding controls: empty)
    A TextValue control to displayAlmost the gauge'ssame current value numerically A Text control above offor the numeric“Text_Value”, valuewith tothese displaydifferences: Format Text = “%04d”, Text Style = Vera96
    • Select the gauge's scope (e.g. speed)
    Another Text control below the numeric value, which can be used to display the unit (e.g. km/h)
    In order to make our control more versatile, various properties of our configured Custom_Gauge (like all images“StackLayout_Texts” and textadd styles)2 willValue bebehaviors made(Toolbox->Behaviors->Value public.Processing->Value). Name them as “Value_TextPos_X” and “Value_TextPos_Y”
    Public Control Properties are those that can be configured when using a Custom_Gauge in a scene.
    Create
    • To each of these behaviors, insert 1 “Set Position” behavior (Behaviors->Value Processing->Transformation->Set Position) as Receiver. Name them “Set Position_X” and Configure“Set TwoPosition_Y”
    TextNodes
    • For both of them, set the target node Custom_Gauge->StackLayout_Texts. Select the proper axis (X for Set Position_X, Y for Set Position_Y)
    • For the “Value_TextPos_X” behavior set the Receiver property Variant= (Float) 205 and afor TextValuethe Node“Value_TextPos_Y”
      behavior, Inconfigure SceneVariant Composer's= Solution(Float) Explorer230. navigate
      • Click at the “Custom_Gauge” control and put “Forward Value” behavior into it
      • Set its target node to “Custom_Gauge->StackLayout_Texts->TextValue”
      • Go to the path“Custom_Gauge”, below and double-click on the "Custom_Gauge"“ControlValueProvider” control.behavior
        and The Scene Tree panel showsset the Custom_GaugeReceivers control'sMaximum tree.value Sceneto editor8000. displaysThen thetry Custom_Gaugeto control.
        change
        its Variant value Path in Solution Explorer Control Solution/Controls Custom_Gauge From the Toolbox panel's Nodes 2D section drag and drop a StackLayout into the Scene Tree panel directly onto the Custom_Gauge node.
          In the Scene Tree panel you can see that a StackLayout has been created directly under the Custom_Gauge node.
          From the Toolbox panel's Controls section under Common drag and drop 2 Text controls and 1 Text Value control into the Scene Tree panel directly onto the StackLayout.
            In the Scene Tree panelso you can see the 2 Text controlstext and theneedle Textupdated. Value
            • controlRight-click directly underat the StackLayout.
            “Custom_Gauge” and select In“Control Properties…”. We will choose which properties should be available from the Scene Tree panel select the StackLayout as wellscene as the 2control Textproperties controls
            • one afterFollow the other and rename them according to the table below either via the context menu entry "Rename" or by pressing <F2> on your keyboard.
              In the Scene Tree panel you can see that the Controls have been renamed.
              Target Item New Name StackLayout StackLayout_Texts Text Text_Top Text_1 Text_Bottom
              In the Scene Tree panel re-arrange StackLayout_Texts and its contents via drag and drop until it looks like in the image below.
                The Scene Tree looks as in the image below.
                In the Scene Tree panel select StackLayout_Texts controls. In the Properties panel under Layouter and Layout adjust the properties as in the table below.
                  In the Properties panel you can see that the correct values are set.
                  Property Value Layouter Arrangement Vertical Layout Vertical Alignment VCenter MinimumSize X 250.00   Y 0.00
                  In the Scene tree panel select Text_Top, Text Value and Text_Bottom one after the other. In the Properties panel under Layout and Control configure the properties as in the table below.
                    In the Properties panel you can see that the correct values are set. In the Scene Editor the texts are centered and the Text Value appears in a bigger font.
                    Property Text_Top Text Value Text_Bottom Layout VerticalAlignment VCenter VCenter VCenter HorizontalAlignment HCenter HCenter HCenter Control Text RPM - <empty String> Text Style
                    OpenSans35
                    Vera96 OpenSans35 Text Alignment Center Center Center Text Format - %04d -
                    Configure the TextNodes' and TextValue Node's Position
                      In the Scene Tree panel select StackLayout_Texts. In the Scene Tree panel's right side click on the [Fusion...] button.
                        Fusion will be opened covering the Scene Editor.
                        StackLayout_Texts Fusion diagram will be displayed. It only has one Fusion Node.
                        In Fusion use the StackLayout_Texts' "Behaviors" connector to add 2 new Fusion Nodes: Connect 2 Value Processing > Value behaviors to the StackLayout_Texts Fusion Node.
                        Please check Fusion's Basic Operations documentation on how to add Fusion Nodes.
                          In Fusion 2 new Fusion Nodes "Value" and "Value_1" have been created.
                          In Fusion select and right-click on the behavior nodes and rename them according to the table below.
                            In Fusion the Value behavior fusion nodes have been renamed.
                            Target Item New Name Value Value_TextPos_X Value_1 Value_TextPos_Y
                            In Fusion use the Value behaviors' "Receivers" connectors to add a Value Processing > Transformation > SetPosition Fusion Node to each of them.
                              In Fusion 2 new Fusion Nodes "Set Position" have been created, one of which is connected to Value_TextPos_X, the other to Value_TextPos_Y.
                                In Fusion the Set Position behavior fusion nodes have been renamed.
                                Target Item New Name Value_TextPos_X > Set Position Set Position_X Value_TextPos_Y > Set Position Set Position_Y In Fusion configure the behaviors' Fusion Nodes according to the table below.
                                  In Fusion the Fusion Nodes' Properties have been changed. In Scene Editor the position of StackLayout_Texts has been changed. The texts are now neatly placed inside the Custom_Gauge control as you can see in the image below.
                                  Fusion Node Property Set Position_X Set Position_Y TargetNode
                                  Custom_Gauge > StackLayout_Texts
                                  Custom_Gauge > StackLayout_Texts TranslationAxis2D AxisX AxisY Property Value_TextPosX Value_TextPosY Variant (Float) 205 (Float) 230
                                    Configure Value Forwarding and Maximum Value
                                      In Fusion add a Value Processing > Forward Value behavior to the Behaviors connector of the Custom_Gauge Fusion Node. Configure its TargetNode according to the table below.
                                        In Fusion the property will be changed accordingly.
                                        Forward Value Fusion Node   Property Value TargetNode Custom_Gauge > StackLayout_Texts > Text Value In Fusion in the ControlValueProvider Fusion Node configure the property Maximum according to the table below.
                                          In Fusion the the property is changed accordingly. Custom_Gauge's Fusion diagram will look as in the image below.
                                          Property Value Maximum (Float) 6000.00
                                            Configure Public Control Properties
                                              In the Scene Tree panel right click "Custom_Gauge" and select "Control Properties..."settings from the contextpictures menu.below:
                                                ForegroundImage:
                                                BackgroundImage:
                                                NeedleImage:
                                                NeedleEffectImage:
                                                Text_Bottom:
                                                Text_Top:
                                                Text_Value:
                                                Value_TextPosX and Value_TextPosY:
                                                • The Configurecustom Publicgauge Controlcontrol Propertiesshould dialog willnow be opened.
                                                In the Configure Public Properties dialog the Properties which should be public to the user of the Custom_Gauge control need to be marked with the "Is Public" checkbox. Check the "Is Public" checkbox and eventually change the image properties' names according to the table and images below.
                                                  Image properties necessary for using and configuring the Custom_Gauge will be made public. The Custom_Gauge control is now fully configuredfinished and ready to use.
                                                  use
                                                  Custom_Gauge > Group_Bitmaps >  Property  Is Public Source Name BackgroundImage > ProvideImageProperty x Image BackgroundImage NeedleImage > ProvideImageProperty x Image NeedleImage NeedleEffectImage > ProvideImageProperty x Image NeedleEffectImage ForegroundImage > ProvideImageProperty x Image ForegroundImage
                                                  In the Configure Public Properties dialog check the "Is Public" checkbox and perform other configurations according to the table and images below.
                                                    Image properties necessary for using and configuring the Custom_Gauge will be made public. The Custom_Gauge control is now fully configured and ready to use.
                                                    The properties made public in this Configure Public Properties dialog will be configurable in the Properties panel's Controls section.
                                                    Custom_Gauge > StackLayout_Texts > Property IsPublic Source Name TextBottom x Text Bottom_Text
                                                    x TextColor Bottom_TextColor
                                                    x TextStyle Bottom_TextStyle Text_Top x Text Top_Text
                                                    x TextColor Top_TextColor
                                                    x TextStyle Top_TextStyle Text Value x FormatText Value_FormatText
                                                    x Style Value_Style
                                                    x TextColor Value_TextColor Behaviors > Value_TextPos_X x Variant TextPosX Behaviors > Value_TextPos_Y x Variant TextPosY
