Extract Bitmaps
Use the Bitmap Extractor component of Asset Tool for extracting bitmaps from a given asset generated with SceneComposer.
Usage
For extracting bitmaps from an asset library file, use the following workflow:
  • Obtain the asset for extracting the bitmaps (e.g., generate asset from SceneComposer);
  • Run AssetTool -extract on this asset;
  • at the path given in the command, the structure of folders containing the bitmaps found in the asset is created.
Command line options:
Extract all bitmaps from the given asset to the output path:
 AssetTool -extract -e assetFilePath outputPath
Show help:
 AssetTool -extract -h
