Memory Pool Configuration
Fragmentation
  • A heap will fragment, when buffers with different lifetimes get allocated
  • Fragmentation endangers system stability over run time
Heap Areas
  • Permanent Allocation
    • will never return the allocated block to the backing heap
    • will be managed by the associated bin (bin free list)
  • Transient Allocation
    • will immediately return the allocated block  to the backing heap
  • Two distinct memory areas
  • The permanent area will never fragment
  • The transient area can fragment
Default Memory Pool Example
Let’s have a look on an example:
static
const
MemoryPoolConfig
 config = FEATSTD_MEMORYPOOL_CONFIG_INITIALIZER( config, // name of the variable receiving the configuration "FeatStdDefaultMemoryPool", // the name of the MemoryPool MemoryPoolFlags::None, // Flags that control the memory pool behavior 128, // all bins up to 128 bytes are small bins cPoolBinSpecs, // the bin configurations 0, // preset allocations DefaultBackingHeap, // type name of the backing heap &OnOutOfMemoryDef, // optional the out of memory function 0 // optional OnDestroy function );
static const BinSpecification cPoolBinSpecs[] = {
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 8), // 732
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 12), // 594
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 16), // 340
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 20), // 143
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 24), // 270
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 28), // 18
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 32), // 156
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 36), // 93
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 40), // 7
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 44), // 128
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 48), // 107
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 52), // 114
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 64), // 30
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 72), // 114
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 76), // 8
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 80), // 9
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 88), // 5
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 92), // 6
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 96), // 8
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 100), // 4
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 108), // 14
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 112), // 5
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 116), // 16
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 120), // 34
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 124), // 54
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 128), // 81
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 136), // 153
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 144), // 145
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 168), // 15
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 180), // 4
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 16384), // 1
    // mandatory final entry
    FEATSTD_MEMORYPOOL_BIN_SPECIFICATION(MemoryPoolBinFlags::None, 0)
Memory Pool Example Outcome
  • This configuration leads to fragmentation
  • All flags (bin & pool) are set to None -> Allocations are always transient
    • Transient allocations can fragment
    • When all allocations are transient, fragmentation is certain
  • Small Bin Limit is set to 128
    • All allocations up to 128 take the best fit bin size + 4 Byte overhead
    • All allocations > 128 take exactly the requested size + 8 Byte overhead
    • The configured bins > 128 are not considered at all, they just consume their header memory
Interpret MemoryPoolAnalysis.xlsx
When a permanent block with size 12800 Byte is used for 160 Byte allocation…
12800
 C:\CGI-Studio_3.10\cgi_studio_candera\src\Candera\Engine2D\Core\RenderNode.cpp(66)
  • The default behavior of Memory Pool for allocations is:
      1. Determine the bin according the requested buffer size
      2. Check the free list of the identified bin
      3. If no block is found in the free list, try to allocate a buffer from the backing heap.
      4. If the allocation from the backing heap fails, try to allocate from the next larger bins (overflow).
  • In the example above, step 4 occurred -> Allocation of a new bin failed!
Proper Memory Pool Analysis
  • A proper configuration for initial analysis…
    has a “small bin limit” of 4 Byte
    • All allocations shall take the requested size
    defines PermanentOnly flag on the pool
    • Bins shall be reused (freed blocks are returned to bin free list)
    defines additionally NoOverflow flag on the pool
    • inhibit overflow allocations
    • If specified, allocation requests from a bin will never overflow to a larger bin
    • Note: a test run with this flag might fail (Out of memory…) due to many unused blocks -> in this case remove the flag
    Proper Memory Pool Configuration
    • A proper final Memory Pool configuration…
      has a “small bin limit” in the upper area (where allocations are rarely)
      • Keep number of transient allocations to a minimum
      uses Flags on bins instead of the pool
      • defines PermanentOnly flag on small bins
      • Defines one bin with None flag, uses transient allocations for large blocks, which are rarely used (no reuse intended)
      uses few bins
      • balance wasted space vs. unused (rarely used) blocks
      Wasted Space vs. Unused blocks
      • Many permanent bins leads to many unused blocks
        • free blocks in bin free list
      • Few permanent bins leads to memory “waste” in blocks
        • Allocation request smaller than block size
      • The memory “waste” of few bins is smaller than free blocks from too many bins.
        • Free bin blocks are reused more often
      Process of Configuration
      • Take dumps with proper configuration for analysis
        • Play more than one use case to get better data
      • If it is not possible to run with flag NoOverflow …
        • Remove the flag
        • Analysis is still valid, most overflows come from low size bins which are anyway “dense”
      • Based on the results
        • Reduce the number of bins drastically
        • Choose a “small bin limit” where allocations are temporary requests Release of temporary memory vs. fragmentation
      Reduce Number of Bins
      Reduce the number of bins generously
      Too many bins -> many free blocks not used
      “Wasted Space” < Not used blocks!
      Choose “Small Bin Limit”
      • Remember: Avoid non used blocks!
      • Summarize bins to small bins as far as possible
      • “Small Bin Limit” shall start where allocations are temporary requests and fragmentation is more unlikely
      Result
      Advanced Topics
      • Pre-Allocation
        • Define how many permanent blocks shall be pre-allocated in each bin
      • Combine with OverflowPreferred flag on bins
        • first try to overflow and then allocate from the backing heap
        • Limit overflows by adding flag OverflowBarrier to bin configuration
        • Such a configuration might improve the memory layout
      • A sophisticated out of memory function could trigger the release of unneeded memory
        • Return value controls if the allocation request will be repeated or abandoned
