Control Behaviors Flags
- CONTROLS_BREADCRUMB_BEHAVIORS_ENABLED - Build with BreadCrumb Behaviors
(BreadcrumbActionBehavior, BreadcrumbBehavior)
- CONTROLS_DEMO_BEHAVIORS_ENABLED - Build with Behaviors intended for demonstration purpose
(ValueGeneratorBehavior)
- CONTROLS_EDITTEXT_BEHAVIORS_ENABLED - Build with Edit Text Behaviors
(CaretBehavior, EditTextBehavior, EnterExitConditionBehavior)
- CONTROLS_EXTERNALRESOURCE_BEHAVIORS_ENABLED - Build with External Resource Behaviors
(ExternalBitmapProviderBehavior, ExternalResourceChangeConditionBehavior, SetExternalBitmapActionBehavior)
- CONTROLS_GLOBALIZATION_BEHAVIORS_ENABLED - Build with Globalization Behaviors
(CultureChangeConditionBehavior, SetCultureActionBehavior)
- CONTROLS_GRAPH_BEHAVIORS_ENABLED - Build with Graph Behaviors
(BarGraphBehavior, LineGraphBehavior)
- CONTROLS_HOVER_EVENT_ENABLED - Activate hover events from Control Touch Session
- CONTROLS_KEYBOARD_BEHAVIORS_ENABLED - Build with Keyboard Behaviors
(KeyboardActionBehavior, KeyboardBehavior)
- CONTROLS_MAP_BEHAVIORS_ENABLED - Build with Map Behaviors
(GeocodingBehavior, MapActionBehavior, MapBridgeBehavior, MapLocationActionBehavior, MapNavigationActionBehavior, NavigationInstructionViewBehavior)
- CONTROLS_MENU_BEHAVIORS_ENABLED - Build with Menu Behaviors
(MenuItemBehavior, MenuScreenActionBehavior, MenuScreenBehavior, PageIndicatorActionBehavior, PageIndicatorBehavior)
- CONTROLS_MESH_BEHAVIORS_ENABLED - Build with Mesh2D Behaviors
(TransformMesh2DBehavior)
- CONTROLS_MIXEDREALITY_BEHAVIORS_ENABLED - Build with Mixed Reality Behaviors
(NavigationPathBehavior, PoiBehavior, PoiConfigBehavior, PoiManagerBehavior, PoseTrackingBehavior)
- CONTROLS_PARTICLE_EMITTER_BEHAVIORS_ENABLED - Build with Particle Emitter Behaviors
(ParticleEmitterBehavior)
- CONTROLS_PLUGIN_CONFIGURATION_ENABLED - Use the output from the "Used Behaviors Plugin". See Used Behaviors Plugin.
- CONTROLS_ROLL_BEHAVIORS_ENABLED - Build with Roll Behaviors
(RollBehavior)
- CONTROLS_SCRIPTING_BEHAVIORS_ENABLED - Build with Scripting Behaviors
(EnableScriptingSystemBehavior)
- CONTROLS_SCROLL_LIST_BEHAVIORS_ENABLED - Build with Scroll & List Behaviors
(ScrollViewBehavior, ListBehavior, SnapListItemConfigurationBehavior, SnapListItemExtensionBehavior, SubListBehavior, ScrollableEventActionBehavior, ScrollbarBehavior)
- CONTROLS_SELECTION_GROUP_BEHAVIORS_ENABLED - Build with Selection Group Behaviors
(ChangeSelectionActionBehavior, SelectionConditionBehavior, SelectionGroupBehavior)
- CONTROLS_SLIDER_BEHAVIORS_ENABLED - Build with Slider Behaviors (Slider, CircularSlider, Dial)
(SliderBehavior, CircularSliderBehavior, DialBehavior)
- CONTROLS_STREAMING_BEHAVIORS_ENABLED - Build with Streaming Behaviors
(VideoStateConditionBehavior, VideoStreamActionBehavior, VideoStreamBehavior)
- CONTROLS_USED_BEHAVIORS_CONFIG_PATH - Path to the output file of the "Used Behaviors Plugin". Flag is only available if flag CONTROLS_PLUGIN_CONFIGURATION_ENABLED is active. See Used Behaviors Plugin.
