Control Behaviors Flags
CONTROLS_GLOBALIZATION_BEHAVIORS_ENABLEDCONTROLS_BREADCRUMB_BEHAVIORS_ENABLED - Build withGlobalizationBreadCrumb Behaviors
(CultureChangeConditionBehavior,BreadcrumbActionBehavior,SetCultureActionBehavior)BreadcrumbBehavior)
(ValueGeneratorBehavior) CONTROLS_EDITTEXT_BEHAVIORS_ENABLED - Build with Edit Text Behaviors
(CaretBehavior, EditTextBehavior, EnterExitConditionBehavior) CONTROLS_EXTERNALRESOURCE_BEHAVIORS_ENABLED - Build with External Resource Behaviors
(ExternalBitmapProviderBehavior, ExternalResourceChangeConditionBehavior, SetExternalBitmapActionBehavior) CONTROLS_GLOBALIZATION_BEHAVIORS_ENABLED - Build with Globalization Behaviors
(CultureChangeConditionBehavior, SetCultureActionBehavior) CONTROLS_GRAPH_BEHAVIORS_ENABLED - Build with Graph Behaviors
(BarGraphBehavior, LineGraphBehavior) CONTROLS_HOVER_EVENT_ENABLED - Activate hover events from Control Touch Session CONTROLS_KEYBOARD_BEHAVIORS_ENABLED - Build with Keyboard Behaviors
(KeyboardActionBehavior, KeyboardBehavior) CONTROLS_MAP_BEHAVIORS_ENABLED - Build with Map Behaviors
(GeocodingBehavior, MapActionBehavior, MapBridgeBehavior, MapLocationActionBehavior, MapNavigationActionBehavior, NavigationInstructionViewBehavior) CONTROLS_MENU_BEHAVIORS_ENABLED - Build with Menu Behaviors
(MenuItemBehavior, MenuScreenActionBehavior, MenuScreenBehavior, PageIndicatorActionBehavior, PageIndicatorBehavior) CONTROLS_MESH_BEHAVIORS_ENABLED - Build with Mesh2D Behaviors
(TransformMesh2DBehavior)
(NavigationPathBehavior,
(ParticleEmitterBehavior) CONTROLS_PLUGIN_CONFIGURATION_ENABLED - Use the output from the "Used Behaviors Plugin". See Used Behaviors Plugin. CONTROLS_ROLL_BEHAVIORS_ENABLED - Build with Roll Behaviors
(RollBehavior) CONTROLS_SCRIPTING_BEHAVIORS_ENABLED - Build with Scripting Behaviors
(EnableScriptingSystemBehavior) CONTROLS_SCROLL_LIST_BEHAVIORS_ENABLED - Build with Scroll & List Behaviors
(ScrollViewBehavior, ListBehavior, SnapListItemConfigurationBehavior, SnapListItemExtensionBehavior, SubListBehavior, ScrollableEventActionBehavior, ScrollbarBehavior)
(ChangeSelectionActionBehavior, SelectionConditionBehavior, SelectionGroupBehavior) CONTROLS_SLIDER_BEHAVIORS_ENABLED - Build with Slider Behaviors (Slider, CircularSlider, Dial)
(SliderBehavior, CircularSliderBehavior, DialBehavior)
Most- Path to the output file of thesethe flags"Used (exceptBehaviors CONTROLS_MIXEDREALITY_BEHAVIORS_ENABLEDPlugin". andFlag CONTROLS_HOVER_EVENT_ENABLED) areis only available withif theflag CONTROLS_PLUGIN_CONFIGURATION_ENABLED is active. See newUsed CMakeBehaviors buildPlugin.
