Animation Editing Modes
Both in Animation Timeline Editor and in Curve Editor, following animation editing modes are available:
    Move key frame without restriction
    Move only between neighbours
    Scale earlier, move later key frames
    Scale key frames
    Shift all key frames
    Move later key frames of all animated properties
    If multiple animated properties are selected (by using the CTRL + left click), the related operation will affect all selected animated properties.
    For "Move key frame without restrictions" and "Move only between neighbours", the operation can only be applied to a single selected key frame.
    06_editing_modes_2.png  The key frame is moved without affecting in any way its neighbours.
    Example: Consider following key frame sequence with an animation duration of 200 msec.
      KF1: 70,
      KF2: 120,
      KF3: 130
      Moving KF2 to 90 ms means -25 % for KF2 without affecting any of its neighbours.
      06_editing_modes_3.png  The selected key frame can only and exclusively be moved between neighbours.
      Example: Consider following key frame sequence with an animation duration of 2000 msec.
        KF1: 500,
        KF2: 1000,
        KF3: 1500
        Moving KF2 means that it can be moved just between 500 and 1500.
        06_editing_modes_4.png  The earlier key frames are scaled, while the later are shifted.
        Example: Consider following key frame sequence with an animation duration of 300 msec.
          KF1: 50,
          KF2: 100,
          KF3: 150,
          KF4: 200
          Moving KF2 to 90 ms means -10 % for earlier key frame and -5 % for later key frames.
            Applying -10 % to KF1: 45,
            Applying -5 % to KF3: 142,5, to KF4: 190.
            Scale key frames
            06_editing_modes_5.png  All key frames are moved in such a way as to keep the relative distance between key frames the same.
              KF1: 200,
              KF2: 700,
              KF3: 1700
              Moving the key frames means to keep the relative distance between key frames the same.
                Applying 612 ms to KF1: 812,
                Applying 867 ms to KF2: 1567,
                Applying 1400 ms to KF3: 3100.
                06_editing_modes_6.png  All the key frames are moved by the same absolute amount as the key frame that is being edited.
                  KF1: 50,
                  KF2: 100,
                  KF3: 150,
                  KF4: 200
                  Moving KF4 to 700 ms means to move +500 ms all the key frames.
                    Applying +500 ms to KF1: 550,
                    Applying +500 ms to KF2: 600,
                    Applying +500 ms to KF3: 650
                    06_editing_modes_7.png  Those key frames placed after a selected one are moved by the same absolute amount.
                      KF1: 50,
                      KF2: 100,
                      KF3: 150,
                      KF4: 200
                      Moving KF2 to 150 ms means to move +50 ms for later key frames.
                        Applying +50 ms to KF3: 200,
                        Applying +50 ms to KF4: 250
