Wayland Linux BSP: Prerequisites
Hardware: NXP i.MX8QMMEK Board
CGI Studio has been tested on NXP i.MX8QMMEK board.
CMake
Linux Toolchain (BSP)
  • Linux version 5.4.3-lts-lf-5.4 (GCC version 9.2.0), Poky 5.4.3 (Zeus) was used to test this release with Weston 7.0.0 (Wayland 1.17.0).
  • SD card image and SDK was prepared following the NXP’s Linux user guide.
  • Graphic driver: Vivante (OpenGL ES 2.0)
Known Limitations
In case open source graphic driver is used (e.g. Etnaviv) following limitations could occur due to driver limitations:
  • issue with shader/s due to limited number of vectors
  • MSAA was not supported
Hardware: STM32MP157C-DK2 board
CGI Studio has been tested on STM32MP157C-DK2 board.
CMake
  • Linux version 5.10.10 (GCC version 9.3.0), ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5.10-dunfell-mp1-21-03-31 (dunfell) was used to test this release with Weston 8.0.0 (Wayland 1.18.0).
  • SD card image and SDK was prepared following the STM’s Linux user guide.
Known Limitations
Hardware: NXP i.MX 8MN board
CGI Studio has been tested on NXP i.MX 8MN board.
CMake
  • Linux version 5.4.70 (GCC version 9.2.0), Poky 5.4 (Zeus) was used to test this release with Weston 9.0.0 (Wayland 1.18.0).
  • SD card image and SDK was prepared following the boards user guide.
  • Graphic driver: Etnaviv (OpenGL ES 3.0)
Known Limitations
Hardware: NXP i.MX 8MM board
CGI Studio has been tested on NXP i.MX 8MM board.
CMake
  • Graphic driver: Etnaviv (OpenGL ES 2.0)
Known Limitations
