Weston Linux BSP: Prerequisites
Contents List
Hardware: NXP i.MX8QMMEK Board
CGI Studio has been tested on NXP i.MX8QMMEK board.
CMake
Linux Toolchain (BSP)
    Linux version 5.4.3-lts-lf-5.4 (GCC version 9.2.0), Poky 5.4.3 (Zeus) was used to test this release with Weston 7.0.0 (Wayland 1.17.0). SD card image and SDK was prepared following the NXP’s Linux user guide. Graphic driver: Vivante (OpenGL ES 2.0)
    Known Limitations
    In case open source graphic driver is used (e.g. Etnaviv) following limitations could occur due to driver limitations:
      issue with shader/s due to limited number of vectors MSAA was not supported
      Back to the menu
      Hardware: STM32MP157C-DK2 board
      CGI Studio has been tested on STM32MP157C-DK2 board.
      CMake
        Linux version 5.10.10 (GCC version 9.3.0), ST OpenSTLinux - Weston - (A Yocto Project Based Distro) 3.1-openstlinux-5.10-dunfell-mp1-21-03-31 (dunfell) was used to test this release with Weston 8.0.0 (Wayland 1.18.0). SD card image and SDK was prepared following the STM’s Linux user guide. Graphic driver: Vivante (OpenGL ES 2.0)
        Known Limitations
          Back to the menu
          Hardware: NXP i.MX 8MN board
          CGI Studio has been tested on NXP i.MX 8MN board.
          CMake
            Linux version 5.4.70 (GCC version 9.2.0), Poky 5.4 (Zeus) was used to test this release with Weston 9.0.0 (Wayland 1.18.0). SD card image and SDK was prepared following the boards user guide. Graphic driver: Etnaviv (OpenGL ES 3.0)
            Known Limitations
              Back to the menu
              Hardware: NXP i.MX 8MM board
              CGI Studio has been tested on NXP i.MX 8MM board.
              CMake
                Linux version 5.4.70 (GCC version 9.2.0), Poky 5.4 (Zeus) was used to test this release with Weston 9.0.0 (Wayland 1.18.0). SD card image and SDK was prepared following the boards user guide. Graphic driver: Etnaviv (OpenGL ES 2.0)
                Known Limitations
                  Back to the menu
