Running the CGI Player Demo Application on Weston Linux
Copy the application and the asset to the target in /home/root folder. This can be done by copying the filed to the SD card containing the file system or via ssh (scp).
Logging Output and Key Input
Use TeraTerm or another terminal software to connect to the target via micro-USB (debugger) to receive logging output and use key input.
BaudRate needs to be setup to 115200 8/n/1/n.
Loading and Running the Application
On target via TeraTerm, navigate (change directory) into the /home/root folder and run the applications with following command:
./<app-name> <asset-name>.bin
