STM32MP157 Target Setup Guide
Before you Begin
- Explore CGI-Studio
Watch the Video Tutorials and read the Quick Start Guide. - Learn to create SceneComposer Solutions
<cgi-studio-installation-path>/bin/SceneComposer/SceneComposer.exe - Generate Assets for Simulation and Target Environments
Software Image Setup
Please note, that this chapter contains links to an external resource (e.g. ST image and wiki). These links were used by Candera for this guide in December 2024 and might have changed in the meanwhile.
Download the official ST target image from here:
STM32MP1Starter - STM32MP1 OpenSTLinux Starter Package - STMicroelectronics
ST Image version 3.1.0 must be used for the CGI Professional Edition 3.15 due some API changes in ST image version 4+.
For the image and hardware setup please follow the official ST guide:
STM32MP15 Discovery kits - Starter Package - stm32mpu
Please be aware of the following potential issues while following the setup guide.
- During image flashing make sure to use the correct extensible FlashLayout file, specific to your hardware.
STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/extensible/FlashLayout_sdcard_stm32mp157x-dk2-extensible.tsv - During the flashing process, we encountered an issue that required us to copy specific files and folders from the extracted stm32mp1.tar archive into the flashlayout_st-image-weston/extensible folder. The following files and folders from the root folder (images\stm32mp1) were necessary in the extensible folder for successful SD card flashing:
|- arm-trusted-firmware
|- fip
- st-image-bootfs-openstlinux-weston-stm32mp1.ext4
- st-image-userfs-openstlinux-weston-stm32mp1.ext4
- st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
- st-image-weston-openstlinux-weston-stm32mp1.ext4
After following the official setup, you should have a running target device with a terminal connection. This is required for the next steps. For the Python installation (needed for Python-based data binding) it is required to connect the target to the internet.
At Candera we have used Tera Term for the remote serial terminal connection and WinSCP for the transfer of files to the target device.
Blood Pressure Sample
The Blood Pressure device sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations.
In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Python PlayerConnector.
For this chapter the completed “Image Setup” is required, and it is assumed that WinSCP is downloaded and installed.
- Connect to the target device with WinSCP.
Launch WinSCP, in the host name field enter the IP address of the target device, and for the username use“root”. Default values should be used for the remaining fields.
Refer to the ST Setup Guide for information on obtaining the device’s IP address.
- Transfer Files to the Target
Use WinSCP to transfer the following files to the target device:
- Target Player executable:
<cgi-installation-path>/bin/TargetPlayer/Player - Solution asset binary file: The asset binary you wish to run.
<cgi-installation-path>/bin/Player/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
- Set Execution Permissions
To set execution permissions before running the asset in the target player, execute the following command in the remote terminal.
chmod +x Player - Run the Asset
The asset will be visible on the target device../Player BloodPressureDevice_Target.bin
In this section, we explain how to execute the Blood Pressure sample including Python-based data binding with our PlayerConnector and how to install the required software on the target. The PlayerConnector allows the simple connection between CGI Studio Player and a Python-based script.
Please note that the “Blood Pressure sample with Python” has been prepared for integration with the Soundhound voice recognition service. For the sake of simplicity in this guide, we will not use this service. By running the sample, you will be presented with a start scene waiting for voice input. As the voice recognition service is not configured, it will not perform any action. To continue using the sample, simply press 'Start'.
For guidance on configuring the voice recognition service by utilizing our Soundhound integration, please refer to our CGI-Studio Documentation: Blood Pressure Sample
Python Installation
Python is required for the PlayerConnector, to enable Python-based data binding for CGI-Studio. The target device needs to have an internet connection for installing python.
This section only covers the Python installation on the target device. In the host environment python can be installed with the help of the python download guide on the python webpage. We have used python version 3.12.6, but the latest version is supported.
To install Python on the target device, follow these steps on the target:
- Update Packages and Install Python.
Run the following commands on the target device with remote terminal:
apt-get update && apt-get upgrade apt-get install python3 - If pip is not installed by default run
python3 -m ensurepip –-upgrade - Verify the installation of pip3 by using the command “pip3”.
Python Script
Before we proceed with executing the script, let's first take a moment to review the key components of the Python PlayerConnector script, which can be found at the following location:
- Import the Python Player Connector library and additional required libraries.
import argparse import time import signal from SoundhoundCommandClient import SoundhoundCommandClient from CanderaAppConnector import CanderaAppConnector, Logger from Generated.BindingSourceEnum import BindingSourceItem - Constructing the library with the connector library binary contained in the delivered package (PlayerConnectorLibrary)
#Getting an instance of the CanderaAppConnector Python class App = CanderaAppConnector(args.LibraryBinaryPath) - Initializing the library with the asset binary
#initializing the player with the asset App.Init(args.AssetBinaryPath) - Set or get databinding values.
#Initializing binding values for back communication App.SetBoolValue(BindingSourceItem.SOURCE2ITEM1, False) App.SetBoolValue(BindingSourceItem.SOURCE2ITEM2, False) App.SetStringValue(BindingSourceItem.SOURCE1ITEM5, TRANSCRIPTION_DEFAULT_STRING) - Optionally register data binding callbacks
def BindingCallback(SourceItem, Value): global menuSceneActive, valueSceneActive ... #Registering databinding callback method App.RegisterCallback(BindingCallback - Continuously calling step to invoke the render loop and internal message delivery
#Looping until sig int try: while not sigintCaptured: ... App.Step() - Interact with data bindings. Note that internally, changes to the data bindings are reflected on the view when App.step() is called
App.SetFloatValue(BindingSourceItem.SOURCE1ITEM1, normalizedProgress * 100.0) - Shutdown library and gracefully exit program
except KeyboardInterrupt: logger.info("Caught KeyboardInterrupt from Python") finally: App.ShutDown() SoundhoundCommandClient.destroy() exit()
More information on the capabilities of our library can be found here.
Run Blood Pressure Sample with PlayerConnector in Simulation Environment (Host)
To run the python-based data binding in the simulation environment (on the host computer) execute the steps below on the host computer:
Please make sure to create a clean copy of the <cgi-studio-installation-path>\bin\Player\PlayerConnector folder before creating the python environment, since this folder is required in its original form for the target.
- Open a command line interface in
- Create and activate a Python environment:
It is recommended to create your own Python environment to keep dependencies isolated. To do this, run in the command line:
python -m venv . Script\activate - Install libraries:
In order to install the PlayerConnector libraries and other required libraries you need to execute
pip install -r requirements.txt - Run Blood Pressure Sample Simulation Asset with Python-based Data Binding
The asset is displayed in host environment.python BloodPressureDevice.py -lbp ..\..\PlayerConnectorLibrary.dll -abp BloodPressureSample_Simulation.bin
Run Blood Pressure Sample with PlayerConnector in Target Environment
It’s assumed that a remote terminal (Tera Term) and WinSCP connection is established.
- Copy required files
Copy the listed folder to the target using using WinSCP.
- PlayerConnector: <cgi-studio-installation-path>/bin/Player/PlayerConnector (all files from this folder are necessary)
- Navigate to the BloodPressureDevice folder
cd <path-to-PlayerConnector-folder>/Samples/BloodPressureDevice - Create and Activate a python environment:
It is recommended to create and activate a python environment by running the following in the remote console:
python3 -m venv . source bin/activate - Install libraries:
In order to install the PlayerConnector library and additional required libraries on the target run this command
pip3 install -r requirements.txt - Run asset with Python-based Data Binding
The asset and the configured databinding are running on the target.python3 BloodPressureDevice.py - lbp ../../libPlayerConnectorLibrary.so -abp BloodPressureSample_Target.bin
This chapter shows how you can create your own solution with Python data binding on host and target with a simple use case. It is using a Gauge Control for HMI data output for the user and a Slider Control for HMI data input via user.
Before proceeding with the example, it is recommended to explore CGI-Studio by viewing the Video Tutorials and the Quick Start Guide, both of which are available in the CGI-Studio Documentation
- Start Scene Composer in <cgi-studio-installation-path>/bin/SceneComposer/Scenecomposer.exe
- Open Empty Solution by either double clicking the empty solution thumbnail or through the File > New Solution dialog.
- In the Render Targets panel (on the right side of the SceneComposer), set the resolution of Display (0) to X Resolution (width) of 800 and Y Resolution (height) of 480.
- Drag and drop a Slider Control and a Gauge Control from the Control section of the Toolbox (on the right side of the Scene Composer) into the Scene Editor.
- You can move the controls in the Scene Editor by selecting the translation icon (the red square in the screenshot below) in the top left corner of the Scene Editor and then selecting the control which you want to move. Just select the item you want to move and drag it to a new location.
- Select the Gauge Control in either the Scene Editor or the Scene Tree, navigate to the properties, and adjust the scale to ensure it fits comfortably within the display.
- To set up a data binding for the Gauge value, first select the Gauge either in the Scene Editor or the Scene Tree. In the properties panel locate the Value property under the Control section and click the chain icon next to it to establish the binding.
- To set a data binding for the Slider property, select the Slider control in either the Scene Editor or the Scene Tree. Then, click the chain icon next to the Value property in the Control section of the Properties panel. Next, choose Item2 (under PredefinedBindingSource1) from the available options.
- Next, generate two asset libraries for both the target and simulation environments to run the solution in the player.
- Save the solution, then go to File > Generate Asset Library
- A popup window will appear each time, allowing you to generate the asset library. Choose your desired asset location, set the environment to “Simulation” for the first run and to “Target” for the next, then click “Generate” to create each asset library.
- Next, create a Python script. You can use the provided Sample.py file in
<cgi-installation-path>/bin/Player/PlayerConnector/Samples/SliderAndGauge/Sample.py. -
Run the asset in the simulation environment (Host):
Do it analogous to the steps from chapter Run Asset with Python PlayerConnector in Simulation Environment (Host).
Important: a requirements.txt file is not necessary, since only the PlayerConnector library needs to be installed:pip install <cgi-studio-installation-path>\bin\Player\PlayerConnector - Run the asset on the target device:
(ensure the device is set up correctly, following the official guide).
Do it analogous to the steps from chapter Run Asset with Python PlayerConnector in Target Environment.
Important: Only the PlayerConnector library needs to be installed on the target:
pip3 install <path-to-player-connector-folder>
Final comments
