STM32MP157 Target Setup Guide
Before you Begin
  • Explore CGI-Studio
    Watch the Video Tutorials and read the Quick Start Guide.
    <cgi-studio-installation-path>/bin/SceneComposer/SceneComposer.exe
  •  Generate Assets for Simulation and Target Environments
Software Image Setup
Please note, that this chapter contains links to an external resource (e.g. ST image and wiki). These links were used by Candera for this guide in December 2024 and might have changed in the meanwhile.
Download the official ST target image from here:
STM32MP1Starter - STM32MP1 OpenSTLinux Starter Package - STMicroelectronics
ST Image version 3.1.0 must be used for the CGI Professional Edition 3.15 due some API changes in ST image version 4+.
For the image and hardware setup please follow the official ST guide:
STM32MP15 Discovery kits - Starter Package - stm32mpu
Please be aware of the following potential issues while following the setup guide.
  1. During image flashing make sure to use the correct extensible FlashLayout file, specific to your hardware.
    STM32_Programmer_CLI -c port=usb1 -w flashlayout_st-image-weston/extensible/FlashLayout_sdcard_stm32mp157x-dk2-extensible.tsv
  2. During the flashing process, we encountered an issue that required us to copy specific files and folders from the extracted stm32mp1 tar archive into the flashlayout_st-image-weston/extensible folder. The following files and folders from the root folder (images\stm32mp1) were necessary in the extensible folder for successful SD card flashing:
    |- arm-trusted-firmware
    |- fip
    - st-image-bootfs-openstlinux-weston-stm32mp1.ext4
    - st-image-userfs-openstlinux-weston-stm32mp1.ext4
    - st-image-vendorfs-openstlinux-weston-stm32mp1.ext4
    - st-image-weston-openstlinux-weston-stm32mp1.ext4
After following the official setup, you should have a running target device with a terminal connection. This is required for the next steps. For the Python installation (needed for Python-based data binding) it is required to connect the target to the internet.
At Candera we have used Tera Term for the remote serial terminal connection and WinSCP for the transfer of files to the target device.
Blood Pressure Sample
The Blood Pressure device sample is a Scene Composer sample that demonstrates a blood pressure measurement device with exemplary scenes and animations.
In this section we will explain how to run the BloodPressureSample with our precompiled target player and with the Python PlayerConnector.
For this chapter the completed “Image Setup” is required, and it is assumed that WinSCP is downloaded and installed.
  • Connect to the target device with WinSCP.
    Launch WinSCP, in the host name field enter the IP address of the target device, and for the username use“root”. Default values should be used for the remaining fields.
    Refer to the ST Setup Guide for information on obtaining the device’s IP address.
  • Transfer Files to the Target
    Use WinSCP to transfer the following files to the target device:
    • Target Player executable:
      <cgi-installation-path>/bin/TargetPlayer/Player
    • Solution asset binary file: The asset binary you wish to run.
      <cgi-installation-path>/bin/Player/PlayerConnector/Samples/BloodPressureDevice/BloodPressureDevice_Target.bin
  • Set Execution Permissions
    To set execution permissions before running the asset in the target player, execute the following command in the remote terminal.
    chmod +x Player
  • Run the Asset
    ./Player BloodPressureDevice_Target.bin
In this section, we explain how to execute the Blood Pressure sample including Python-based data binding with our PlayerConnector and how to install the required software on the target. The PlayerConnector allows the simple connection between CGI Studio Player and a Python-based script.
Please note that the “Blood Pressure sample with Python” has been prepared for integration with the Soundhound voice recognition service. For the sake of simplicity in this guide, we will not use this service. By running the sample, you will be presented with a start scene waiting for voice input. As the voice recognition service is not configured, it will not perform any action. To continue using the sample, simply press 'Start'.
For guidance on configuring the voice recognition service by utilizing our Soundhound integration, please refer to our CGI-Studio Documentation: Blood Pressure Sample
Python Installation
Python is required for the PlayerConnector, to enable Python-based data binding for CGI-Studio. The target device needs to have an internet connection for installing python.
This section only covers the Python installation on the target device. In the host environment python can be installed with the help of the python download guide on the python webpage. We have used python version 3.12.6, but the latest version is supported.
To install Python on the target device, follow these steps on the target:
  • Update Packages and Install Python.
    Run the following commands on the target device with remote terminal:
    apt-get update && apt-get upgrade
    apt-get install python3
  • If pip is not installed by default run
    python3 -m ensurepip –-upgrade
  • Verify the installation of pip3 by using the command “pip3”.
Python Script
Before we proceed with executing the script, let's first take a moment to review the key components of the Python PlayerConnector script, which can be found at the following location:
  1. Import the Python Player Connector library and additional required libraries.
    import argparse
    import time
    import signal
    from SoundhoundCommandClient import SoundhoundCommandClient
  2. Constructing the library with the connector library binary contained in the delivered package (PlayerConnectorLibrary)
    #Looping until sig int
    try:
        while not sigintCaptured:
        App.Step()
    normalizedProgress * 100.0)
    except KeyboardInterrupt:
    finally:
        App.ShutDown()
    exit()
Run Blood Pressure Sample with PlayerConnector in Simulation Environment (Host)
To run the python-based data binding in the simulation environment (on the host computer) execute the steps below on the host computer:
Please make sure to create a clean copy of the <cgi-studio-installation-path>\bin\Player\PlayerConnector folder before creating the python environment, since this folder is required in its original form for the target.
  • Create and activate a Python environment:
    It is recommended to create your own Python environment to keep dependencies isolated. To do this, run in the command line:
    python -m venv .
    Script\activate
  • Install libraries:
    In order to install the PlayerConnector libraries and other required libraries you need to execute
    pip install -r requirements.txt
    python BloodPressureDevice.py
    -lbp  ..\..\PlayerConnectorLibrary.dll
    -abp BloodPressureSample_Simulation.bin
Run Blood Pressure Sample with PlayerConnector in Target Environment
It’s assumed that a remote terminal (Tera Term) and WinSCP connection is established.
  • Copy required files
    Copy the listed folder to the target using using WinSCP.
    • PlayerConnector: <cgi-studio-installation-path>/bin/Player/PlayerConnector (all files from this folder are necessary)
    cd <path-to-PlayerConnector-folder>/Samples/BloodPressureDevice
  • Create and Activate a python environment:
    It is recommended to create and activate a python environment by running the following in the remote console:
    python3 -m venv .
    source bin/activate
    In order to install the PlayerConnector library and additional required libraries on the target run this command
    pip3 install -r requirements.txt
    python3 BloodPressureDevice.py -
    lbp ../../libPlayerConnectorLibrary.so -abp
    BloodPressureSample_Target.bin
This chapter shows how you can create your own solution with Python data binding on host and target with a simple use case. It is using a Gauge Control for HMI data output for the user and a Slider Control for HMI data input via user.
Before proceeding with the example, it is recommended to explore CGI-Studio by viewing the Video Tutorials and the Quick Start Guide, both of which are available in the CGI-Studio Documentation
  • Start Scene Composer in <cgi-studio-installation-path>/bin/SceneComposer/Scenecomposer.exe
  • Next, create a Python script. You can use the provided Sample.py file in
    <cgi-installation-path>/bin/Player/PlayerConnector/Samples/SliderAndGauge/Sample.py.
    Do it analogous to the steps from chapter Run Asset with Python PlayerConnector in Simulation Environment (Host).
    Important:
    a requirements.txt file is not necessary, since only the PlayerConnector library needs to be installed:
    (ensure the device is set up correctly, following the official guide).
    Do it analogous to the steps from chapter Run Asset with Python PlayerConnector in Target Environment.
    Important: Only the PlayerConnector library needs to be installed on the target:
    pip3 install <path-to-player-connector-folder>
Final comments
