Target setup guide for the ESP32S3 (ESP32S3-Touch-LCD-2.8C)
Before you Begin
  • Explore CGI-Studio
    Watch the Video Tutorials and read the Quick Start Guide.
Setup
Template Scenes
IfWhen using a template scene is used as athe base for developmentdevelopment, the SurfaceFormatsurfaceFormat inside the RenderTarget needs to be set to SurfaceFormatRGB565SurfaceFormatRGB565.
IDE
To compile a CourierSampleApp Example for the target ESP IDF needs to be installed within Visual Studio Code: Getting Started with VS Code IDE - ESP32 - — ESP-IDF Programming Guide v4.3.1 documentation
Device Connection to host PC
The ESP32S3-Touch-LCD-2.8C target from waveshare has two USB-C ports. For flashing connect the one labled "UART" to the host PC.
Compile and flash
Inside cgi_studio_apps\References\ESP-IDF a example project can be found. Open this project within Visual Studio code
It might be necessary to adjust the selected COM port. For this click the COM<current port number> on the bottom task bar and select one of the available com ports:
To compile and flash the target press the ESP-IDF: Build, Flash and Monitor on the bottom Task bar.
After compilation and flashing an example project can be seen on the display of the ESP32S3.
Replacing the Asset File
The current setup requires the Asset binary file to be converted to a C Array that can be placed directly within the code. For converting the binaries bin2c from segger can be used:
 This program generates a file with a C array inside. This array needs to be copied into the following file: cgi_studio_courier_apps\src\CourierSampleAppLight\AppPlatform\Target_FreeRTOS_XTENSA\Solution.c
The array needs to look like the following: const unsigned char _acBasicSolution2D_ac2D_Basic.  Inside the AppEnvironment.cpp file of the same directory this array is referenced.referenced:
extern const unsigned char _ac2D_Basic[1130352UL + 1];
#define ASSET_START _ac2D_Basic
When updating the Solution.c make sure that the size of the Arrayarray is the same asinside Solution.c and in Solution.c.AppEnvironment.cpp
After the array has been replaced the project can be recompiled and flashed like described in the previous step.
