Running the Player Demo Application on R-Car H3 Integrity
Asset
An asset (statically linked) has been pre-built and is located here:
  • [...]/cgi_studio_courier_apps/src/CourierSampleApp/Assets/AssetLibCff_RCarH3_Integrity_Target.bin
Asset loading from file system (if required)
Note:
Application side only, this is not part of the original port.
To enable set:
  •  #define __LOAD_ASSET_FROM_FILE
in:
  • [...]/cgi_studio_courier_apps/src/CourierSampleApp/AppPlatform/Target_RCarH3Integrity_ARM/AppEnvironment.cpp
and set this variable to the correct file system path:
  • Courier::Char * cAssetFileName = "...";
also, remove:
  • -rawimport ${ASSET_TARGET_LOCATION}
  • [...]/cgi_studio_courier_apps/src/CourierSampleApp/AppPlatform/Target_RCarH3Integrity_ARM/KernelTargets/KernelTargets.cmake
SceneComposer Solution
  • [...]/cgi_studio_courier_apps/src/CourierSampleApp/SCSolution/RCarH3
Flash
  • in MULTI (v7.4.1) Launcher choose 'Open Debugger' -> C:/ghs/int1144/config/bin/multivisor_vm0_vm1_mono
  • (if not yet done) load 'CANDERA_default.con' from 'Target' -> 'Show Connection Organizer'
  • press 'F5' (green arrow button) and select:
    • * '[CANDERA] Flash Kernel (mpserv) for Renesas R-Car H3'
    • * select 'Download to RAM' when asked
  • chose 'File' -> 'Debug as new Entry' -> [...]/CourierSampleApp_RCarH3Platform_Target_RCarH3Integrity_ARMIntDyn
  • chose 'Debug' -> 'Prepare Taget' and select:
    • * '[CANDERA] Load Dynamic Download (rtserv2) for Renesas R-Car H3'
  • wait until application is loaded (~ half a minute)
Notes
  • the result of the build will be a dynamic build file:
    • "CourierSampleApp_RCarH3Platform_Target_RCarH3Integrity_ARMIntDyn"
  • along with the sample app two additional VAS are loaded (but not started):
    • -> noload_as_1 (WM_Server_as0) and noload_as_2 (MMGR_Server_as0)
  • this is a workaround to overcome a dynamic download issue not solved yet.
