Building Own Application for R-Car D3 Draak Integrity
Generate Makefiles with CMake
To configure and generate makefiles for compiling the Player, follow below steps:
- Folder containing top-level "CMakeLists.txt", e.g. \
cgi_studio_player\srccmake\Candera\Player
- Configure
- \cgi_studio_devices\src\RCarD3\ToolchainFiles\MULTI-toolchain-RCarD3_draak_custom_1.txt
- Adapt the CMake settings if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release
- Press Configure
- Press Generate
Building Application
Via the CMake variable CGIDEVICE_BSP_CFG_NAME, it is possible to choose the BSP library configuration. By default this is set to release (rel), however, it is also possible to choose debug (dbg), checked (chk) resp. coverage (cov).
