Hardware setup for NXP RT117X
Required Tools and Equipment
The following tools and equipment are needed to set up and run the project:
  • NXP RT117X hardware board with display.display
CGI Studio (Minimum version 3.15.1) CMake GUI Visual Studio Code Ninja Build Tool Required binary files (.bin) IAR Embedded Workbench Board Support Packages Hardware Variants
Hardware Revision Supported Display Supported BSP versions Notes
Rev_a  720 ×× 1280 only Up to BSP 2.16 BSP versions higher than 2.16 are not supported
Rev_b 720 ×× 1280 or 800 ×× 480 (Raspberry Pi Display) 2.16 and newer
(e.g., 25_06_00)
Supports newer BSP versions
Hardware Connection Setup
  1. Connect the power cable to the NXP RT117X board.
  2. Connect the Micro-USB port on the board to a USB-A port on your laptop or PC.
  3. Make sure the Micro-USB is connected to the USB Debug port.
  4. Power on the board.
  5. Check if the power LEDs on the board are glowing.
  6. Wait for your system to detect the board. You can verify this by checking Device Manager →→ Ports (COM & LPT) —— a new COM port should appear for the NXP RT117X board
Verification after completing the flashing
  1. Confirm that the display output matches the expected layout from Scene Composer.
  2. Check that images, colors, and animations render correctly.
  3. Validate Bitmap Stride behavior for both aligned and unaligned images.
  4. Ensure there are no visual distortions or flickering.
