Building Own Application for Nullws
Generate Makefiles with CMake
  1. Open a terminal.
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    • Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
  6. Configure
    • Specify Unix Makefiles as generator for the project.
    • Specify tool-chain file for cross-compiling.
    cgi_studio_devices/src/DrmKms/ToolchainFiles/GCC-toolchain-<platform>-Nullws-Linux.txt
  8. Adapt the CMake settings, if necessary, e.g.:
    • CMAKE_BUILD_TYPE-> Debug or Release.
    • Enable/disable features.
    • Press Configure.
  9. Press Generate.
Building Application
  1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
