Building Own Application for iMX6 Integrity
Compile Tool Chain Preparations
Make sure to install the tool chain as described in iMX6 Integrity Prerequisites
Generate Makefiles with CMake
To configure and generate makefiles for compiling the Player for IMX6 Integrity, follow below steps:
- Folder containing top-level "CMakeLists.txt", e.g. \cgi_studio_player\src
- Configure
- \cgi_studio_candera\cmake\toolchain-files\MULTI-toolchain-iMX6-Sabre.txt
- Adapt the CMake settings if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release
- Press Configure
- Press Generate
If the package supports "harfbuzz" as CANDERA_TEXTSHAPER please set this entry appropriately because by default it is set to "ComplexLib". Resume the configuration by pressing “Configure” again.
Building Application
The output monolith file can be found in your build directory's subfolder CGIApplication.
Open this file with the Green Hills MULTI IDE debugger and load it to RAM as described in the previous chapter.
