Building Own Application for Fbdev
Generate Makefiles with CMake
- Open a terminal.
- Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
Dolphin 5 (Yocto based SDK)$source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>Allwinner T507 (Buildroot based SDK)
export SDKTARGETSYSROOT=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot export PATH=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH - Important! From the same console with the set environment start the CMake GUI or run the CMake commandline. We will continue with the CMake GUI in this guide.
Allwinner T507 (Buildroot based SDK)cd <build directory> cmake-gui .
cd <build directory> # Environment variables for sdk export SDKTARGETSYSROOT="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot" export PATH="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH" export SYSROOT="$SDKTARGETSYSROOT" export SDKSYSROOT="$SYSROOT" export PKG_CONFIG="/usr/bin/pkg-config" export PKG_CONFIG_SYSROOT_DIR="$SYSROOT" export PKG_CONFIG_PATH="$SYSROOT/usr/lib/pkgconfig" export CXX="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-g++ --sysroot=$SYSROOT" export CC="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-gcc --sysroot=$SYSROOT" export LD="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin/aarch64-linux-gnu-ld --sysroot=$SYSROOT" cmake-gui . - Point CMake to source directory
- Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
- Configure
- Specify Unix Makefiles as generator for the project.
- Specify tool-chain file for cross-compiling.
cgi_studio_devices/src/Fbdev/ToolchainFiles/GCC-toolchain-<platform>-Fbdev-Linux.txt - Adapt the CMake settings, if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release.
- Enable/disable features.
- Press Configure.
- Press Generate.
Building Application
Make sure that the environment variables for the
YoctoYocto/Buildroot SDK are set in the terminal! Either reuse the terminal used to start CMake for building the Player or call the environment setup script again.
export SDKTARGETSYSROOT="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysrootsysroot"
export PATH="/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATHPATH"
- Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
- After generating your cmake files, navigate to the specified build directory (binary directory created in CMake GUI) and type "make" to start the build or “make -j” to build with multithreading.
