Building Own Application for Fbdev
Generate Makefiles with CMake
- Open a terminal.
- Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
Dolphin 5 (Yocto based SDK)$source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>Allwinner T507 (Buildroot based SDK)
export SDKTARGETSYSROOT=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/aarch64-buildroot-linux-gnu/sysroot export PATH=/home/candera/Desktop/OKT507-linux-sdk20/out/t507/okt507/longan/buildroot/host/bin:$PATH - Important! From the same console with the set environment start the CMake GUI or run the CMake commandline. We will continue with the CMake GUI in this guide.
- Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
- Configure
- Specify Unix Makefiles as generator for the project.
- Specify tool-chain file for cross-compiling.
cgi_studio_devices/src/Fbdev/ToolchainFiles/GCC-toolchain-<platform>-Fbdev-Linux.txt - Adapt the CMake settings, if necessary, e.g.:
- CMAKE_BUILD_TYPE-> Debug or Release.
- Enable/disable features.
- Press Configure.
- Press Generate.
Building Application
- Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
- After generating your cmake files, navigate to the specified build directory (binary directory created in CMake GUI) and type "make" to start the build or “make -j” to build with multithreading.
