DRM/KMS: Prerequisites
Contents List
Hardware: Raspberry Pi 4
CGI Studio has been tested on  Raspberry Pi 4 Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned here.
Linux Toolchain (BSP)
  • Create an SD card image with Raspberry Pi Imager - Raspberry Pi OS 64 Legacy, 64-bit (Debian Bullseye). Make sure to activate ssh access. This can be done with the Raspberry Pi Imager advanced options (strg+shift+x).
  • Start the target
  • On Target install the *-dev packages needed for your application plus
    apt-get -yqq update && \
        apt-get -yqq install libinput-dev libudev-dev libgles2-mesa-dev libdrm-dev libgbm-dev libegl1-mesa-dev
If an image with display server is used please make sure to boot to cli. On host install a VM / WSL with Ubuntu 20.04 LTS (Focal Fossa)
    apt-get -yqq install python3 build-essential crossbuild-essential-armhf crossbuild-essential-arm64
Install CMake
Copy /usr/lib and /usr/include from target SD Card to /opt/raspberry/bullseye/sysroot or /opt/raspberry/bullseye/sysroot64 if you use the 64 bit version.
Compiler/s used for this release is GCC (GNU 9.4.0).
Hardware: iMX8QM
CGI Studio has been tested on Toradex Apalis iMX8QM Board.
CMake
  • Yocto 6.6.0 built at Candera according to Toradex manuals.
  • Image and SDK were prepared by the Candera.
  • The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
  • Compiler/s used for this release is GCC (GNU 11.4.0).
Hardware: R-Car E3
CGI Studio has been tested on R-Car E3 System Evaluation Board.
CMake
  • The SDK used for this release is based on Yocto Poky 2.4.3.
  • SD card image and SDK were prepared by according to the RCar-E3 user guide.
  • GCC (GNU 7.3.0)
Hardware: R-Car M3N
CGI Studio has been tested on R-Car M3N Customer Board.
CMake
  • Yocto Poky 3.1.11 provided by the customer was used to test this release .
  • Image and SDK were prepared by the customer.
  • Compiler/s used for this release is GCC (GNU 9.3.0).
