DRM/KMS: Prerequisites
Contents List
Hardware: Raspberry Pi 4
CGI Studio has been tested on Toradex Apalis Raspberry Pi 4 Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned here.
Linux Toolchain (BSP)
    Create an SD card image with Raspberry Pi Imager - Raspberry Pi OS 64 Legacy, 64-bit (Debian Bullseye) Start the target   On Target install the *-dev packages needed for your application plus
    apt-get -yqq update && \
        apt-get -yqq install libinput-dev libudev-dev libgles2-mesa-dev libdrm-dev libgbm-dev libegl1-mesa-dev
    On host install a VM / WSL with Ubuntu 20.04 LTS (Focal Fossa)
        apt-get -yqq install python3 build-essential crossbuild-essential-armhf crossbuild-essential-arm64
    Install CMake
    Copy /usr/lib and /usr/include from target SD Card to /opt/raspberry/bullseye/sysroot or /opt/raspberry/bullseye/sysroot64 if you use the 64 bit version.
    Compiler/s used for this release is GCC (GNU 9.4.0).
    Hardware: iMX8QM
    CGI Studio has been tested on Toradex Apalis iMX8QM Board.
    CMake
    • Yocto 6.6.0 built at Candera according to Toradex manuals.
    • Image and SDK were prepared by the Candera.
    • The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
    • Compiler/s used for this release is GCC (GNU 11.4.0).
    Hardware: R-Car E3
    CGI Studio has been tested on R-Car E3 System Evaluation Board.
    CMake
    • The SDK used for this release is based on Yocto Poky 2.4.3.
    • SD card image and SDK were prepared by according to the RCar-E3 user guide.
    • GCC (GNU 7.3.0)
    Hardware: R-Car M3N
    CGI Studio has been tested on R-Car M3N Customer Board.
    CMake
    • Yocto Poky 3.1.11 provided by the customer was used to test this release .
    • Image and SDK were prepared by the customer.
    • Compiler/s used for this release is GCC (GNU 9.3.0).
