DRM/KMS R-Car E3 BSP: Prerequisites
Contents List
Hardware: iMX8QM
CGI Studio has been tested on Toradex Apalis iMX8QM Board.
CMake
Linux Toolchain (BSP)
The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer. Compiler/s used for this release is GCC (GNU 11.4.0).
Hardware: R-Car E3
CGI Studio has been tested on R-Car E3 System Evaluation Board.
CMake
- The SDK used for this release is based on Yocto Poky 2.4.3.
- SD card image and SDK were prepared by according to the RCar-E3 user guide.
- The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
Compiler/s used for this release is - GCC (GNU 7.3.0)
Hardware: R-Car M3N
CGI Studio has been tested on R-Car M3N Customer Board.
CMake
- Yocto Poky 3.1.11 provided by the customer was used to test this release .
- Image and SDK were prepared by the customer.
- Compiler/s used for this release is GCC (GNU 9.3.0).
