DRM/KMS R-Car E3 BSP: Prerequisites
Contents List
Hardware: R-Car E3
CGI Studio has been tested on R-Car E3 System Evaluation Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version mentioned here.here.
Linux Toolchain (BSP)
  • The SDK used for this release is based on Yocto Poky 2.4.3.
  • SD card image and SDK were prepared by according to the RCar-E3 user guide.
  • The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer.
    Compiler/s used for this release is
  • GCC (GNU 7.3.0)
Hardware: R-Car M3N
CGI Studio has been tested on R-Car M3N Customer Board.
CMake
  • Yocto Poky 3.1.11 provided by the customer was used to test this release .
  • Image and SDK were prepared by the customer.
  • Compiler/s used for this release is GCC (GNU 9.3.0).
