DRM/KMS R-Car E3 BSP: Prerequisites
Contents List
Hardware: R-Car E3
CGI Studio has been tested on R-Car E3 System Evaluation Board.
CMake
In order to build Candera, the Meta build system CMake needs to be installed with at least version 3.16.3mentioned here.
R-Car
Linux E3Toolchain Yocto(BSP)
The
The SDK used for this release is based on Yocto Poky 2.4.3.
GCC
SD image and SDK were prepared by according to the RCar-E3 user guide.
The GCC compiler is not part of the delivery. It is contained in theCompiler/s used for this release is GCC (GNU 7.3.0)
Hardware: R-Car M3N
CGI Studio has been tested on R-Car M3N Customer Board.
CMake
Linux Toolchain (BSP)
The GCC compiler is not part of the delivery. It is contained in the SDK that has to be provided by the customer. Compiler/s used for this release is GCC (GNU 9.3.0).
