Building Own Application for DRM/KMS
Generate Makefiles with CMake
  1. Open a terminal.
    $source /<path to the Yocto SDK installation>/environment-setup-<platform specific suffix e.g. aarch64-poky-linux>
    • Folder containing top-level "CMakeLists.txt", e.g. /cmake/Candera/Player
  6. Configure
    • Specify Unix Makefiles as generator for the project.
    • Specify tool-chain file for cross-compiling.
    cgi_studio_devices/src/DrmKms/ToolchainFiles/GCC-toolchain-<platform>-DrmKms-Linux.txt
  8. Adapt the CMake settings, if necessary, e.g.:
    • CMAKE_BUILD_TYPE-> Debug or Release.
    • Enable/disable features.
    • Press Configure.
  9. Press Generate.
Building Application
  1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
  2. After generating your cmake files, navigate to the specified build directory (binary directory created in CMake GUI) and type "make" to start the build or ““make -j”j” to build with multithreading.
    With some hypervisors, the Linux VM may get unresponsive when using the ––j option. Reducing the number of used threads to the number of available cores improves the responsiveness of the VM during the build.
