Building Own Application for DRM/KMS R-Car E3
Generate Makefiles with CMake
  1. Open a terminal.
     $source /<path to the Yocto SDK installation>/environment-setup-aarch64-poky-linux
    • Folder containing top-level "CMakeLists.txt", e.g. /cgi_studio_player/src
  6. Configure
    • Specify Unix Makefiles as generator for the project.
    • Specify tool-chain file for cross-compiling.
  8. If your target requires EGL_DEFALT_DISPLAY as EGLNativeDisplayHandle and 0 as EGLDefaultWindowHandle please add "set(CGIDEVICE_BYPASS_DRMKMS_DISPLAY_WINDOW_ACQUISITION ON) to the toolchain file. You could also set CGIDEVICE_BYPASS_DRMKMS_DISPLAY_WINDOW_ACQUISITION to ON in the CMake GUI or add the definition when you call CMake from the command line.
cgi_studio_devices/src/DrmKms/ToolchainFiles/GCC-toolchain-RCarGen3-DrmKms-Linux.txt Adapt the CMake settings, if necessary, e.g.:
  • CMAKE_BUILD_TYPE-> Debug or Release.
  • Enable/disable features.
  • Press Configure.
Press Generate.
Building Application
  1. Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake.
