Building Own Application for DRM/KMS R-Car E3
Generate Makefiles with CMake
    Open a terminal. Set the environment. This step is mandatory. Omitting this step will cause building with the host systems compiler instead of cross compiling.
     $source /<path to the Yocto SDK installation>/environment-setup-aarch64-poky-linux
    Important! From the same console with the set environment start the CMake GUI or run the CMake commandline. We will continue with the CMake GUI in this guide. Point CMake to source directory
      Folder containing top-level "CMakeLists.txt", e.g. /cgi_studio_player/src
      Point CMake to binary directory
        May not exist, create folder with CMake if necessary Root directory for generated makefiles / solutions Root directory for build artifacts
        Configure
          Specify Unix Makefiles as generator for the project. Specify tool-chain file for cross-compiling.
          Select the toolchain-file from the delivery (adapt for your toolchain installation and application specific needs) cgi_studio_devices/src/DrmKms/ToolchainFiles/GCC-toolchain-RCarGen3-DrmKms-Linux.txt Adapt the CMake settings, if necessary, e.g.:
            CMAKE_BUILD_TYPE-> Debug or Release. Enable/disable features. Press Configure. Press Generate.
            Building Application
              Open CMake GUI and configure the project (e.g Player, CourierSampleApp, CitDemoApp) according to Generate Makefiles with CMake. After generating your cmake files, navigate to the specified build directory (binary directory created in CMake GUI) and type "make" to start the build or “make -j” to build with multithreading.
