Candera Device Packages
Supported Device Packages
Candera provides device implementations for following device types:
Name Description Possible values
Android
ON/OFF
Other proprietary devices Can be provided upon special request ON/OFF
Device-Specific CMake Settings
CGIDEVICE_NAME The name of the device package Each device package following the Candera device CMake rules provided in the folder <CANDERA_SRC>/CanderaPlatform/Device
CGIDEVICE_TARGET_BUILD Enable or disable building for target ON/OFF
CGISTUDIO_PATH_3RD_PARTY Path to the 3rd party repository location A string value containing the system file location of 3rd party software, auto-detected by finding possible locations of the name "[ic01_]cgi_studio_3psw"
CGIDEVICE_TARGET_
<CGIDEVICE_NAME>
_DRIVER_PATH_INCLUDE
If you don't use the default driver path, the path to the driver include directory can be changed with this setting. Path to driver include directory (by default set to include directory in 3rd party repository)
CGIDEVICE_TARGET_
<CGIDEVICE_NAME>
_DRIVER_PATH_LIB
If you don't use the default driver path, the path to the driver library directory can be changed with this setting. Path to driver library directory (by default set to library directory in 3rd party repository)
To build a certain device package selected it from the drop-down list of the CMake property "CGIDEVICE_NAME":
For each device package, either building OpenGL based host simulation or target binaries can be selected via the Boolean CMake property "CGIDEVICE_TARGET_BUILD".
The following table illustrates configurations available for the supported device package:
CGIDEVICE_NAME CGIDEVICE_TARGET_BUILD PUB_CGI_CPU PUB_CGI_OS Default driver path following
<CGISTUDIO_PATH_3RD_PARTY>
/[src/lib]/
The CMake properties "PUB_CGI_CPU", "PUB_CGI_OS" usually cannot be configured via the CMake user interface, but are autonomously detected by
the build system. The same applies for the variable "PUB_CGI_COMPILER".
If you don't use the CGI Studio 3rd party software folder structure, the driver paths can be specified in the variables
  • CGIDEVICE_TARGET_<CGIDEVICE_NAME>_DRIVER_PATH_INCLUDE and
  • CGIDEVICE_TARGET_<CGIDEVICE_NAME >_DRIVER_PATH_LIB
Depending on these properties, either MS Visual Studio solutions or Unix makefiles will be generated into the specified build
directory.
