New Solution Wizard
When a new Solution is created as shown in the previous step, it is possible to use the New Solution Wizard. Here, important parts of the solution can be configured:
  • Set dimension, resolution, clear color and color depth for the display, rendertarget and 2D camera.
  • Manage the import of .fbx files.
  • Manage the import images.
After clicking "Finish", the solution will be created with a configured display, rendertarget and camera, including the imported .fbx and image files.
In the ImportView of the "New Solution Wizard", it is possible to delete selected items before they are imported.
"New Solution" - Configure the Display
"New Solution" - Import FBX files
"New Solution" - Manage Imported .fbx Files using the Delete Option
"New Solution" - Import Images
It is possible to cancel the creation of a new solution at any moment by using the "Cancel" button. There is the possibility to finish the process of creating a new solution with the Wizard at any step by hitting the "Finish" button. If this option is chosen, it will be necessary to do all the successive configuration and importing manually.
