Diagram Bird's Eye
This feature provides a Bird's eye view of the entire Fusion diagram and marks the current location in the Fusion panel with a blue frame (see figure below, click to enlarge). It is useful for getting a bird's eye view of the entire Fusion diagram when composing a Fusion diagram.
How to use
  1. Select [ View > Fusion > Diagram Bird's Eye ] from the menu bar to display the Diagram Bird's Eye panel.
    • Normally, the panel is displayed as a floating window.
    • Before displaying the Fusion panel, only the message "Diagram is invisible. Double click to open diagram." will appear in the Diagram Bird's Eye panel.
  2. Display the Fusion panel.
    • The fusion diagram in the panel is shown in the Diagram Bird's Eye panel.
    • By dragging the blue frame in the Diagram Bird's Eye with mouse operation, the diagram displayed in the Fusion panel is also moved.
Toolbar in Diagram Bird's Eye
[ Zoom ] in the lower left part of Diagram Bird's Eye panel is linked to [ Zoom ] in the toolbar of Fusion panel. Changing the [ Zoom ] in Fusion panel will also change the zoom value in Diagram Bird's Eye (The reverse operation yields the same result.).
When [ Zoom ] in Diagram Bird's Eye panel is changed, the size of the blue frame in the panel changes.
