Clear Solution Cache
For an opened solution the Scene Composer uses for opened solution a solution cache, which is stored in %appdata% directory of the user. In some casescases, the clearclearing of the solution cache might fix thesome one or other problemproblems (e.g. working in teams on the same solutions). and free up some space.
By clicking on "Clear Solution Cache" in the File menu,menu the cache of the currently opened solution will resetbe (this includes removing cache files, reset the file index and configuration table).cleared. The solution itself will not be modified, just the cache, used by Scene Composer, will be reset.modified.
