Clear Solution Cache
Scene Composer uses for opened solution a solution cache.cache, which is stored in %appdata% directory of the user. In raresome cases itthe clear of the solution cache might makefix sensethe toone resetor other problem (e.g. working in teams on the same solutions).
By clicking on "Clear Solution Cache" in the File menu, the cache of the currentcurrently opened solution andwill createreset. aThis newincludes removing cache fromfiles, reset the scratch.file
index and configuration table. The solution itself will not be modified, just the cache, used by Scene Composer, will be reset.
