Transition panel
This page describes the panels you can use when configuring and executing transitions.
Transition Rules Editor
The Transition Rule Editor panel can be displayed by checking [ View > Transitions > Transition Rules Editor ] on the menu bar.
(1)
Add new ransition rule:
Add a new transition rule.
(2)
Delete transition rule:
Deletes the selected transition rule.
(3)
Search:
If many transition rules are set, you can enter a search term to narrow down the number of results displayed.
(4)
Clear Search:
Delete the search term you entered.
(5)
Source:
Set the source of the transition.
(6)
Transition Type:
Set the transition type.
(7)
Destination:
Set the destination of the transition.
(8)
Activation/Deactivation:
Set the activation delay/deactivation delay.
(9)
Variant:
Sets the transition rule variant.
Transition Execution
The Transition Execution panel can be displayed by checking [ View > Transitions > Transition Execution ] on the menu bar.
(1)
Add an example of a new transition execution:
Add an example of a new transition execution.
(2)
Delete transition execution example:
Delete the selected transition execution example.
(3)
Add an example of how to use a scene:
Add an example of using a scene to the transition execution example.
(4)
Delete Scene Example:
Delete the selected scene example.
(5)
Execute Transitions:
Run an example of a transition.
(6)
Scene:
Set the scene to be transitioned.
(7)
Action:
Set the action to be taken by the transition.
(Activate: Transition to the set scene, Deactivate: Transition from the set scene to another scene)
(8)
Variant:
For more information on how to configure transitions, please refer to Concepts and Use Cases and Using Transitions.
