Shader Configuration
The Solution option allows for Default Shader Configurations.
Contents List
Add a New Vertex or Fragment Shader
  • Vertex Shaders
  • Fragment (or Pixel) Shaders
For information about how to import a Vertex or Fragment shader please refer to section How to Import Resources.
Back to the menu
Add a New Shader Program
Create a new shader program:
Use the context menu option "New Shader Program" of any node within the shader program category from the Shaders panel.
Back to the menu
Shader Editor
  • Select a vertex or fragment shader in the Shaders panel
  • Select a shader program in the Shaders panel
  • The vertex shader in the left side and
  • The fragment shader in the right side.
Shader Editor Features
The context menu of the Shader Editor provides "Cut", "Copy", "Paste", "Delete", "Select All" functions for editing shader instructions:
  • By using menu item "Shader" > "Compile Shader" or
  • by pressing F7 key.
For further information please refer to section Compile Shaders.
Back to the menu
Compile Shaders
Shader compilation is triggered in the following situations:
  1. During shader editing, if requested via menu item "Shader" > "Compile Shader" or by pressing F7 key, the selected shader or shader program will be compiled using the platform's shader compiler.
  2. During scene editing, when the scene dependencies are generated, the shaders will be compiled using an internal shader compiler (so called "builtin://DefaultShaderCompiler").
  3. During asset generation, depending on the selected shader compiler type, the shaders will be compiled using platform's shader compiler (Target) or internal shader compiler (Simulation).
The compilation result can be seen in the "Problems Browser" panel. For further information please refer to section Problems Browser.
Back to the menu
Shader Parameters
SceneComposer offers the necessary support to define shader parameters for uniform and attribute values. For every shader, Candera supplies a list of uniforms and their corresponding types. Uniforms are set via UniformSetters.
  • A new category named "Shader Parameters" is loaded for every node, after choosing a Shader Program from Properties panel.
  • The available uniforms are displayed and desired values can be set for them after choosing a proper Uniform Setter from the "Uniform Setter" property list.
Back to the menu
Instanceable Shaders
  • All uniforms (except certain auto-uniforms) are defined as arrays - an error will be emitted otherwise
  • The sizes of the array uniforms must be the same - an error will be emitted otherwise
  • "u_PMatrix", // ProjectionMatrix4
  • "u_CamPosition", // CameraPosition
  • "u_CamDirection", // CameraLookAtVector
  • "u_Texture", // Texture
  • "u_Texture1", // Texture1
  • "u_Texture2", // Texture2
  • "u_Texture3", // Texture3
  • "u_Texture4", // Texture4
  • "u_Texture5", // Texture5
  • "u_Texture6", // Texture6
  • "u_Texture7", // Texture7
  • "u_CubeMapTexture", // CubeMapTexture
  • "u_CubeMapTexture1", // CubeMapTexture1
  • "u_CubeMapTexture2", // CubeMapTexture2
  • "u_CubeMapTexture3", // CubeMapTexture3
  • "u_CubeMapTexture4", // CubeMapTexture4
  • "u_CubeMapTexture5", // CubeMapTexture5
  • "u_CubeMapTexture6", // CubeMapTexture6
  • "u_CubeMapTexture7", // CubeMapTexture7
  • "u_Light[0].type", // LightType
  • "u_Light[1].type", // LightType1
  • "u_Light[2].type", // LightType2
  • "u_Light[3].type", // LightType3
  • "u_Light[4].type", // LightType4
  • "u_Light[5].type", // LightType5
  • "u_Light[6].type", // LightType6
  • "u_Light[7].type", // LightType7
  • "u_Light[0].ambient", // LightAmbient
  • "u_Light[1].ambient", // LightAmbient1
  • "u_Light[2].ambient", // LightAmbient2
  • "u_Light[3].ambient", // LightAmbient3
  • "u_Light[4].ambient", // LightAmbient4
  • "u_Light[5].ambient", // LightAmbient5
  • "u_Light[6].ambient", // LightAmbient6
  • "u_Light[7].ambient", // LightAmbient7
  • "u_Light[0].diffuse", // LightDiffuse
  • "u_Light[1].diffuse", // LightDiffuse1
  • "u_Light[2].diffuse", // LightDiffuse2
  • "u_Light[3].diffuse", // LightDiffuse3
  • "u_Light[4].diffuse", // LightDiffuse4
  • "u_Light[5].diffuse", // LightDiffuse5
  • "u_Light[6].diffuse", // LightDiffuse6
  • "u_Light[7].diffuse", // LightDiffuse7
  • "u_Light[0].specular", // LightSpecular
  • "u_Light[1].specular", // LightSpecular1
  • "u_Light[2].specular", // LightSpecular2
  • "u_Light[3].specular", // LightSpecular3
  • "u_Light[4].specular", // LightSpecular4
  • "u_Light[5].specular", // LightSpecular5
  • "u_Light[6].specular", // LightSpecular6
  • "u_Light[7].specular", // LightSpecular7
  • "u_Light[0].position", // LightPosition
  • "u_Light[1].position", // LightPosition1
  • "u_Light[2].position", // LightPosition2
  • "u_Light[3].position", // LightPosition3
  • "u_Light[4].position", // LightPosition4
  • "u_Light[5].position", // LightPosition5
  • "u_Light[6].position", // LightPosition6
  • "u_Light[7].position", // LightPosition7
  • "u_Light[0].direction", // LightDirection
  • "u_Light[1].direction", // LightDirection1
  • "u_Light[2].direction", // LightDirection2
  • "u_Light[3].direction", // LightDirection3
  • "u_Light[4].direction", // LightDirection4
  • "u_Light[5].direction", // LightDirection5
  • "u_Light[6].direction", // LightDirection6
  • "u_Light[7].direction", // LightDirection7
  • "u_Light[0].halfplane", // LightHalfplane
  • "u_Light[1].halfplane", // LightHalfplane1
  • "u_Light[2].halfplane", // LightHalfplane2
  • "u_Light[3].halfplane", // LightHalfplane3
  • "u_Light[4].halfplane", // LightHalfplane4
  • "u_Light[5].halfplane", // LightHalfplane5
  • "u_Light[6].halfplane", // LightHalfplane6
  • "u_Light[7].halfplane", // LightHalfplane7
  • "u_Light[0].attenuation", // LightAttenuation
  • "u_Light[1].attenuation", // LightAttenuation1
  • "u_Light[2].attenuation", // LightAttenuation2
  • "u_Light[3].attenuation", // LightAttenuation3
  • "u_Light[4].attenuation", // LightAttenuation4
  • "u_Light[5].attenuation", // LightAttenuation5
  • "u_Light[6].attenuation", // LightAttenuation6
  • "u_Light[7].attenuation", // LightAttenuation7
  • "u_Light[0].spotCosCutoff", // LightSpotCosCutoff
  • "u_Light[1].spotCosCutoff", // LightSpotCosCutoff1
  • "u_Light[2].spotCosCutoff", // LightSpotCosCutoff2
  • "u_Light[3].spotCosCutoff", // LightSpotCosCutoff3
  • "u_Light[4].spotCosCutoff", // LightSpotCosCutoff4
  • "u_Light[5].spotCosCutoff", // LightSpotCosCutoff5
  • "u_Light[6].spotCosCutoff", // LightSpotCosCutoff6
  • "u_Light[7].spotCosCutoff", // LightSpotCosCutoff7
  • "u_Light[0].spotExponent", // LightSpotExponent
  • "u_Light[1].spotExponent", // LightSpotExponent1
  • "u_Light[2].spotExponent", // LightSpotExponent2
  • "u_Light[3].spotExponent", // LightSpotExponent3
  • "u_Light[4].spotExponent", // LightSpotExponent4
  • "u_Light[5].spotExponent", // LightSpotExponent5
  • "u_Light[6].spotExponent", // LightSpotExponent6
  • "u_Light[7].spotExponent", // LightSpotExponent7
  • "u_Light[0].range", // LightRange
  • "u_Light[1].range", // LightRange1
  • "u_Light[2].range", // LightRange2
  • "u_Light[3].range", // LightRange3
  • "u_Light[4].range", // LightRange4
  • "u_Light[5].range", // LightRange5
  • "u_Light[6].range", // LightRange6
  • "u_Light[7].range", // LightRange7
  • "u_Light[0].enabled", // LightEnabled
  • "u_Light[1].enabled", // LightEnabled1
  • "u_Light[2].enabled", // LightEnabled2
  • "u_Light[3].enabled", // LightEnabled3
  • "u_Light[4].enabled", // LightEnabled4
  • "u_Light[5].enabled", // LightEnabled5
  • "u_Light[6].enabled", // LightEnabled6
  • "u_Light[7].enabled", // LightEnabled7
  • "u_Light[0].cameraLookAtVector",// LightCameraLookAtVector
  • "u_Light[1].cameraLookAtVector",// LightCameraLookAtVector1
  • "u_Light[2].cameraLookAtVector",// LightCameraLookAtVector2
  • "u_Light[3].cameraLookAtVector",// LightCameraLookAtVector3
  • "u_Light[4].cameraLookAtVector",// LightCameraLookAtVector4
  • "u_Light[5].cameraLookAtVector",// LightCameraLookAtVector5
  • "u_Light[6].cameraLookAtVector",// LightCameraLookAtVector6
  • "u_Light[7].cameraLookAtVector",// LightCameraLookAtVector7
Back to the menu
Shader Consistency Checker
Warning Diagnostic Possible resolutions
SemanticNotMappedToUniform, SemanticNotMappedToAttribute This problem is reported when a uniform or attribute semantic is not mapped to any parameter name in the shader.
  • change the attribute mapping
ShaderAttributeNotMappedToSemantic This problem is reported when the shader contains an attribute which is not mapped to a semantic.
  • edit shader in case the attribute was spelt incorrectly
VBAttributeMissing This problem is reported when an attribute defined in the shader has no matching data in the vertex buffer.
  • generate the missing attribute (if possible)
  • select a different shader program or vertex buffer
VBAttributeTypeInvalid This problem is reported when the type of the vertex data or the type of the attribute defined in the shader is invalid or there was an error retrieving them. - select a different shader program or vertex buffer
VBAttributeTypeExtraChannels This problem is reported when the vertex data contains too many channels compared to the attribute defined in the shader. For example an attribute is defined in the shader as a vector of 2 floats and the vertex data has a vector of 3 floats.
  • regenerate the attribute from the vertex buffer (if possible)
  • edit the shader
VBAttributeTypePotentialPrecisionLoss This problem is reported when there is a (potential) precision loss while loading the attribute data contained in the vertex buffer into the attributed defined in the shader. For example vertex data type is Float32 and the shade attribute type is Medium Float.
  • change the precision of the attribute from the vertex buffer (if possible)
  • edit the shader
VBAttributeTypePrecisionWaste This problem is reported when there is a "precision waste" while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is Int8 and the shader attribute type is High Int.
  • edit the shader
VBAttributeTypeConversionToInt, VBAttributeTypeConversionToFloat This problem is reported when there is a type conversion while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is float and the shader attribute type is int.
  • edit the shader
SemanticNotSupportedByUniformSetterButUsedByShaderProgram This problem is reported when the semantic of a uniform defined in the shader is not supported by the uniform setter. Currently all semantic are supported.
SemanticNotEnabledInUniformSetterButUsedByShaderProgram This problem is reported when the semantic of a uniform defined in the shader is not enabled in the uniform setter.
  • enable the semantic in the uniform setter
  • enable flag auto activation for the uniform setter
SemanticEnabledInUniformSetterButNotUsedByShaderProgram This problem is reported when the semantic of a uniform not defined in the shader is enabled in the uniform setter.
  • disable enable the semantic in the uniform setter
Back to the menu
Generic ShaderParamSetter
A relationship between the semantics of the UniformSetter and all the properties of the shader should be established. The semantics of the UniformSetter contain specific values that could be activated/deactivated in direct relationship with the shader. In In [ Solution Option >Default Shader Params ] from the menu bar allows to change the default names of all these values specific for the semantics of the UniformSetter.
Back to the menu
    Clone, Rename, Delete a Shader
    Use the context menu of a shader program in the Shaders panel to trigger one of the following options:
    • "Clone" will make a copy of the shader program. The name of the copy will be the name of the item suffixed with a number.
    • "Delete" will cause a "Delete solution item" dialog to appear. If the item is not used somewhere in the solution, it can be deleted by clicking "OK". If the item is used, the "Delete Solution Item" dialog will list the paths of the items where it is used, and the "OK" is disabled, making the deletion not possible.
    • "Rename" will cause a "Rename Solution Item" dialog to appear. The new desired name can be typed in the text box.
    Back to the menu
