Shader Configuration
Contents List
Add a New Vertex or Fragment Shader
Vertex Shaders
Fragment (or Pixel) Shaders
For information about how to import a Vertex or Fragment shader please refer to section Import Shaders.
Back to the menu
Add a New Shader Program
Create a new shader program:
Back to the menu
Shader Editor
Shader Editor
Select a vertex or fragment shader in the Shaders panel
Select a shader program in the Shaders panel
The vertex shader in the left side and
The fragment shader in the right side.
Shader Editor Features
For further information please refer to section Compile Shaders.
Back to the menu
Compile Shaders
Shader compilation is triggered in the following situations:
During shader editing, if requested via menu item "Shader" > "Compile Shader" or by pressing F7 key, the selected shader or shader program will be compiled using the platform's shader compiler.
During scene editing, when the scene dependencies are generated, the shaders will be compiled using an internal shader compiler (so called "builtin://DefaultShaderCompiler").
During asset generation, depending on the selected shader compiler type, the shaders will be compiled using platform's shader compiler (Target) or internal shader compiler (Simulation).
Back to the menu
Shader Parameters
Shader Parameters
SceneComposer offers the necessary support to define shader parameters for uniform and attribute values. For every shader, Candera supplies a list of uniforms and their corresponding types. Uniforms are set via UniformSetters.
A new category named "Shader Parameters" is loaded for every node, after choosing a Shader Program from Properties panel.
The available uniforms are displayed and desired values can be set for them after choosing a proper Uniform Setter from the "Uniform Setter" property list.
Back to the menu
Instanceable Shaders
All uniforms (except certain auto-uniforms) are defined as arrays - an error will be emitted otherwise
The sizes of the array uniforms must be the same - an error will be emitted otherwise
"u_PMatrix", // ProjectionMatrix4
"u_CamPosition", // CameraPosition
"u_CamDirection", // CameraLookAtVector
"u_Texture", // Texture
"u_Texture1", // Texture1
"u_Texture2", // Texture2
"u_Texture3", // Texture3
"u_Texture4", // Texture4
"u_Texture5", // Texture5
"u_Texture6", // Texture6
"u_Texture7", // Texture7
"u_CubeMapTexture", // CubeMapTexture
"u_CubeMapTexture1", // CubeMapTexture1
"u_CubeMapTexture2", // CubeMapTexture2
"u_CubeMapTexture3", // CubeMapTexture3
"u_CubeMapTexture4", // CubeMapTexture4
"u_CubeMapTexture5", // CubeMapTexture5
"u_CubeMapTexture6", // CubeMapTexture6
"u_CubeMapTexture7", // CubeMapTexture7
"u_Light[0].type", // LightType
"u_Light[1].type", // LightType1
"u_Light[2].type", // LightType2
"u_Light[3].type", // LightType3
"u_Light[4].type", // LightType4
"u_Light[5].type", // LightType5
"u_Light[6].type", // LightType6
"u_Light[7].type", // LightType7
"u_Light[0].ambient", // LightAmbient
"u_Light[1].ambient", // LightAmbient1
"u_Light[2].ambient", // LightAmbient2
"u_Light[3].ambient", // LightAmbient3
"u_Light[4].ambient", // LightAmbient4
"u_Light[5].ambient", // LightAmbient5
"u_Light[6].ambient", // LightAmbient6
"u_Light[7].ambient", // LightAmbient7
"u_Light[0].diffuse", // LightDiffuse
"u_Light[1].diffuse", // LightDiffuse1
"u_Light[2].diffuse", // LightDiffuse2
"u_Light[3].diffuse", // LightDiffuse3
"u_Light[4].diffuse", // LightDiffuse4
"u_Light[5].diffuse", // LightDiffuse5
"u_Light[6].diffuse", // LightDiffuse6
"u_Light[7].diffuse", // LightDiffuse7
"u_Light[0].specular", // LightSpecular
"u_Light[1].specular", // LightSpecular1
"u_Light[2].specular", // LightSpecular2
"u_Light[3].specular", // LightSpecular3
"u_Light[4].specular", // LightSpecular4
"u_Light[5].specular", // LightSpecular5
"u_Light[6].specular", // LightSpecular6
"u_Light[7].specular", // LightSpecular7
"u_Light[0].position", // LightPosition
"u_Light[1].position", // LightPosition1
"u_Light[2].position", // LightPosition2
"u_Light[3].position", // LightPosition3
"u_Light[4].position", // LightPosition4
"u_Light[5].position", // LightPosition5
"u_Light[6].position", // LightPosition6
"u_Light[7].position", // LightPosition7
"u_Light[0].direction", // LightDirection
"u_Light[1].direction", // LightDirection1
"u_Light[2].direction", // LightDirection2
"u_Light[3].direction", // LightDirection3
"u_Light[4].direction", // LightDirection4
"u_Light[5].direction", // LightDirection5
"u_Light[6].direction", // LightDirection6
"u_Light[7].direction", // LightDirection7
"u_Light[0].halfplane", // LightHalfplane
"u_Light[1].halfplane", // LightHalfplane1
"u_Light[2].halfplane", // LightHalfplane2
"u_Light[3].halfplane", // LightHalfplane3
"u_Light[4].halfplane", // LightHalfplane4
"u_Light[5].halfplane", // LightHalfplane5
"u_Light[6].halfplane", // LightHalfplane6
"u_Light[7].halfplane", // LightHalfplane7
"u_Light[0].attenuation", // LightAttenuation
"u_Light[1].attenuation", // LightAttenuation1
"u_Light[2].attenuation", // LightAttenuation2
"u_Light[3].attenuation", // LightAttenuation3
"u_Light[4].attenuation", // LightAttenuation4
"u_Light[5].attenuation", // LightAttenuation5
"u_Light[6].attenuation", // LightAttenuation6
"u_Light[7].attenuation", // LightAttenuation7
"u_Light[0].spotCosCutoff", // LightSpotCosCutoff
"u_Light[1].spotCosCutoff", // LightSpotCosCutoff1
"u_Light[2].spotCosCutoff", // LightSpotCosCutoff2
"u_Light[3].spotCosCutoff", // LightSpotCosCutoff3
"u_Light[4].spotCosCutoff", // LightSpotCosCutoff4
"u_Light[5].spotCosCutoff", // LightSpotCosCutoff5
"u_Light[6].spotCosCutoff", // LightSpotCosCutoff6
"u_Light[7].spotCosCutoff", // LightSpotCosCutoff7
"u_Light[0].spotExponent", // LightSpotExponent
"u_Light[1].spotExponent", // LightSpotExponent1
"u_Light[2].spotExponent", // LightSpotExponent2
"u_Light[3].spotExponent", // LightSpotExponent3
"u_Light[4].spotExponent", // LightSpotExponent4
"u_Light[5].spotExponent", // LightSpotExponent5
"u_Light[6].spotExponent", // LightSpotExponent6
"u_Light[7].spotExponent", // LightSpotExponent7
"u_Light[0].range", // LightRange
"u_Light[1].range", // LightRange1
"u_Light[2].range", // LightRange2
"u_Light[3].range", // LightRange3
"u_Light[4].range", // LightRange4
"u_Light[5].range", // LightRange5
"u_Light[6].range", // LightRange6
"u_Light[7].range", // LightRange7
"u_Light[0].enabled", // LightEnabled
"u_Light[1].enabled", // LightEnabled1
"u_Light[2].enabled", // LightEnabled2
"u_Light[3].enabled", // LightEnabled3
"u_Light[4].enabled", // LightEnabled4
"u_Light[5].enabled", // LightEnabled5
"u_Light[6].enabled", // LightEnabled6
"u_Light[7].enabled", // LightEnabled7
"u_Light[0].cameraLookAtVector",// LightCameraLookAtVector
"u_Light[1].cameraLookAtVector",// LightCameraLookAtVector1
"u_Light[2].cameraLookAtVector",// LightCameraLookAtVector2
"u_Light[3].cameraLookAtVector",// LightCameraLookAtVector3
"u_Light[4].cameraLookAtVector",// LightCameraLookAtVector4
"u_Light[5].cameraLookAtVector",// LightCameraLookAtVector5
"u_Light[6].cameraLookAtVector",// LightCameraLookAtVector6
"u_Light[7].cameraLookAtVector",// LightCameraLookAtVector7
Back to the menu
Shader Consistency Checker
Warning
Diagnostic
Possible resolutions
SemanticNotMappedToUniform, SemanticNotMappedToAttribute
This problem is reported when a uniform or attribute semantic is not mapped to any parameter name in the shader.
change the attribute mapping
ShaderAttributeNotMappedToSemantic
This problem is reported when the shader contains an attribute which is not mapped to a semantic.
edit shader in case the attribute was spelt incorrectly
VBAttributeMissing
This problem is reported when an attribute defined in the shader has no matching data in the vertex buffer.
generate the missing attribute (if possible)
select a different shader program or vertex buffer
VBAttributeUnused
This problem is reported when the vertex buffer contains data for an attribute and that attribute is not defined in the shader.
remove the unused attribute from the vertex buffer (if possible)
VBAttributeTypeInvalid
This problem is reported when the type of the vertex data or the type of the attribute defined in the shader is invalid or there was an error retrieving them.
- select a different shader program or vertex buffer
VBAttributeTypeMissingChannels
This problem is reported when the vertex data does not contain enough channels to match the attribute defined in the shader. For example an attribute is defined in the shader as a vector of 2 floats and the vertex data has only one float.
regenerate the attribute from the vertex buffer (if possible)
edit the shader
VBAttributeTypeExtraChannels
This problem is reported when the vertex data contains too many channels compared to the attribute defined in the shader. For example an attribute is defined in the shader as a vector of 2 floats and the vertex data has a vector of 3 floats.
edit the shader
VBAttributeTypePotentialPrecisionLoss, VBAttributeTypePrecisionLoss
This problem is reported when there is a (potential) precision loss while loading the attribute data contained in the vertex buffer into the attributed defined in the shader. For example vertex data type is Float32 and the shade attribute type is Medium Float.
change the precision of the attribute from the vertex buffer (if possible)
edit the shader
VBAttributeTypePrecisionWaste
This problem is reported when there is a "precision waste" while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is Int8 and the shader attribute type is High Int.
edit the shader
VBAttributeTypeConversionToInt, VBAttributeTypeConversionToFloat
This problem is reported when there is a type conversion while loading the attribute data contained in the vertex buffer into the attribute defined in the shader. For example vertex data type is float and the shader attribute type is int.
edit the shader
SemanticNotSupportedByUniformSetterButUsedByShaderProgram
This problem is reported when the semantic of a uniform defined in the shader is not supported by the uniform setter. Currently all semantic are supported.
SemanticNotEnabledInUniformSetterButUsedByShaderProgram
This problem is reported when the semantic of a uniform defined in the shader is not enabled in the uniform setter.
enable the semantic in the uniform setter
enable flag auto activation for the uniform setter
SemanticEnabledInUniformSetterButNotUsedByShaderProgram
This problem is reported when the semantic of a uniform not defined in the shader is enabled in the uniform setter.
disable enable the semantic in the uniform setter
Back to the menu
Generic ShaderParamSetter
A relationship between the semantics of the UniformSetter and all the properties of the shader should be established. The semantics of the UniformSetter contain specific values that could be activated/deactivated in direct relationship with the shader. The Shader Params Editor (which may be opened from the File menu "Solution Options" > "Default Shader Params...") allows to change the default names of all these values specific for the semantics of the UniformSetter.
Back to the menu
Default Shader Configuration
Once a new 3D object is created in a 3D scene in SceneComposer, a default shader is used for the Appearance of the 3D object. The default shader configuration can be manipulated in SceneComposer and initially looks like this:
3D Object Type
Default Shader (Vertex - Fragment - Shaderpair)
Billboard
RefTrans_RefTex
Mesh with no texture
RefTransLight1_RefColor
Mesh with one texture
RefTransLight1_RefColorTex
PointSprite
RefTransPointSprite_RefPointSprite
FBX Import - Default Shader Configuration
During FBX import, no automatic shader assignment for the imported scene is performed. This means the imported nodes have no shader attachments in the node appearance, and rendering is done according to a default shader configuration as specified in the Default Shader Configuration dialog ("Shader" > "Default Shader Configuration"):
Back to the menu
Clone, Rename, Delete a Shader
"Clone" will make a copy of the shader program. The name of the copy will be the name of the item suffixed with a number.
"Delete" will cause a "Delete solution item" dialog to appear. If the item is not used somewhere in the solution, it can be deleted by clicking "OK". If the item is used, the "Delete Solution Item" dialog will list the paths of the items where it is used, and the "OK" is disabled, making the deletion not possible.
"Rename" will cause a "Rename Solution Item" dialog to appear. The new desired name can be typed in the text box.
Back to the menu
