Referencing external resource
External resources can be referenced and drawn on the scene editor. This feature is only available when launching Scene Composer on the Android platform.
Resource Reference Menu
[ Set External Resource Path... ] in the menu bar under [ File ] to browse external resources. This menu is grayed out and not selectable for Scene Composer on non-Android platforms.
Referable external resource file formats are *.bmp, *.jpg, *.jpeg, *.gif, *.tga, *.png, *.dds, *.hdr, and *.exr.
Basic Usage
- Run Scene Composer and open a new or existing solution file.
- From [ File ] menu in the menu bar, select [ Set External Resource Path... ].
- The ExternalResourceContainerPlugin dialog will appear.
- Click the [ Browse... ] button in the dialog to select the external resource folder to be referenced.
- Select the Android Studio project folder.
The behaviors Set External Bitmap, Check External Resource Change, and External Bitmap Provider are used to display external resources. For details on each behavior,behavior and their usage, please refer to this page.
