Databinding UI
Each bindable property have a button next to the property that allows to define a binding.
Following items have bindable properties: Behaviors, Widgets, Behavior, Building and BlocksControls
When unbound, clicking the button shows the databinding dialog that allows to link the property to a data source.
The binding dialog shows all matching datatypes in the editor:
WhenData bound,items displayed in the [ Define Data Binding ] dialog are normally displayed in definition file order. By checking the [ Sort Alphabetically ] checkbox in the dialog, data items are displayed in alphabetical order.
The order in which the currently used items are displayed can also be changed in the Live Preview panel, which is displayed via [ View > Live Preview ] in the menu bar, by using the [ Sort Alphabetically ] checkbox.
Buttons for bound property items are displayed in blue (white for unbound buttons). To remove the bound setting, click on the button willto breakdisplay a dialog box, then click on the link[ betweenUnbind ] button at the propertybottom andof the datadialog source (see hover icon in the image below) allowing the next click to bind the property again.
The buttons indicate if a binding is established or not:box.
