3D Scene Editor
FiveThis page describes the five types of interactions that are possible with the render view:view.
Contents List
    Camera Manipulation
    Camera Sequence Editor
    Context Resource Pool
    Camera Group
    Camera Gizmos
    Light Gizmos
    Navigation Panel
    See Also : 3D Editing Helpers
    Camera Manipulation
    • "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light. Scene Editor provides a navigation panel on the bottom right so the  objects can be viewed from all sides.
    The scene has to contain an object of type Light to ensure proper lighting in the scene.
    Perspective Camera (Editor):
    Orthogonal Cameras:
    Scene Camera View
    Camera Panning and Zooming
    Camera Look-At Node
    Camera Preview Thumbnail
    Even though the current selected camera is the Perspective camera, it is possible to see the content displayed by another camera in the thumbnail available in property grid. If the camera is not associated to a render target, the preview will be done on a fixed size virtual render target surface:
    • 100x100px for 3D cameras
    Reset Camera
    Back to the menu
    When many cameras are associated to the same Render Target, editing of the camera sequence can be done in two different ways. The first one is done by following these four steps:
    • In the Render Targets panel select one camera associated to the respective render target;
    • Press the F3 key on your keyboard; in this way, the (0) sequence number which is placed next to the name of the camera between round brackets will become editable;
    • Press the Enter key.
    The second way to edit the sequence of all cameras associated with the same Render Target is based on the usage of button "Go to Camera Sequence Editor view" which is placed in the Render Targets panel right to the Search field.
    When this button is selected, a window with all the cameras from the entire solution is displayed. The filter button "Show only associated cameras" on the left allows to filter just those cameras which are associated to a render target. In the list displayed, every camera has an associated field where the sequence number can be edited.
    Back to the menu
    Back to the menu
    Camera Group
    After creating a CameraGroup, it will be visible in the "Camera Group Explorer View". A camera group is a flat list of camera groups identified by a unique name.
    Any camera from any scene can be dragged from the Scene Tree inside the group.
    Another way to add a camera to the group is by using the context menu: right click on a camera and select the "Add Camera To Camera Group" option.
    Any camera inside the group can be locked or unlocked, enabled or disabled. Initially, all newly added cameras are ordered alphabetically. It is possible to change this order manually by dragging the cameras in the desired position.
    When a camera is a added into a Camera Group it will become a member of an array where all the other cameras are included. If one of those cameras added into a Camera Group is removed, the "Delete Items" panel will become available and the user will have the possibility to use the "Remove Array Item" resolution. In this way, the selected camera will be removed from the array of cameras contained by the Camera Group.
    Back to the menu
    Camera Gizmos
    LookAtVector
    Up Direction
    Editing is done by click-and-drag the ring around the camera body (which is highlighted with yellow when selected). The current up-vector will be rotated around the world looking-at direction, obtaining a "rolling" effect considering the Y mouse movement.
    Projection
    For Perspective view a wireframe frustum is provided, constructed to suggest fov,znear and zfar; for Orthographic view a wireframe rectangular prism is provided, constructed to suggest width, height, znear, zfar; for Generic projection no impersonator is provided.
    Back to the menu
    Light Gizmos
    Direction
    Editing is done by click-and-drag on the direction arrow. The direction vector will be rotated by a free rotation alt-azimuthally model, using both X and Y mouse movement.
    Range
    Spot Exponent
    Spot Angle
    Back to the menu
    Select
    Translate
    Rotate
    Scale
    Editing Aids
    Unselect an Item
    Back to the menu
    Navigation Panel
    1
    2
    3
    4
      Makes zoom out, zoom in
    Back to the menu
