3D Scene Editor
Contents List
- Camera Manipulation
- Camera Sequence Editor
- Context Resource Pool
- Camera Group
- Camera Gizmos
- Light Gizmos
- Picking and Transforming Items
- Navigation Panel
See Also : 3D Editing Helpers
Camera Manipulation
- "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light. Scene Editor provides a navigation panel on the bottom right so the objects can be viewed from all sides.
- "Orthogonal" cameras with the subcategories Front, Rear, Top, Bottom, Left and Right: Orthogonal projection is a means of representing a three-dimensional object in two dimensions.
- Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree or Scene Editor panel.
- The scene has to contain an object of type Light to
ensureqwa2properensure proper lighting in the scene.
Perspective Camera (Editor):
Orthogonal Cameras:
Scene Camera View
Camera Panning and Zooming
- Panning: Move the mouse while holding the middle mouse button down
- Zooming: Rotate the mouse wheel forward for zooming in and backward for zooming out
Camera Look-At Node
Camera Preview Thumbnail
Even though the current selected camera is the Perspective camera, it is possible to see the content displayed by otheranother camera in the thumbnail available in property grid. If the camera is not associated to a render target, the preview will be done on a fixed size virtual render target surface:
- 100x100px for 3D cameras
- on a surface of the same aspect ratio as the render target, and then reduced to a thumbnail image - for 3D cameras
Reset Camera
SelectIn(inthe Render Targetspanel)panel select one camera associated to the respective render target;- Press the F3
keyboardkeykey;on your keyboard; in this way, the (0) sequence number which is placed next to the name of the camera between round brackets will become editable; - Choose and write the desired sequence number;
- Press the Enter key.
The second way to edit the sequence of all cameras associated with the same Render Target is based on the usage of button "Swap"Go buttonto Camera Sequence Editor view" which is placed in the Render Targets panel afterright to the Search field.
When the "Swap"this button is selected, a window with all the cameras from the entire solution is displayed. The filter button "Show only associated cameras" buttonon the left allows to filter just those cameras which are associated to a render target. EveryIn the list displayed, every camera has an associated a field where the sequence number can be edited.
Camera Group
- Via "Add" > "New item" option by using the Scene Explorer context menu. Creates a Camera group in a folder specified by the user during this process.
After creating a CameraGroup, it will be visible in the "Camera Group Explorer View". A camera group is a flat list of camera groups identified by ana unique name.
After the creation of a camera group, anyAny camera from any scene can be dragged from the Scene Tree inside the group.
Another way to add a camera to the group is by using the context menu: right click on thea camera group and select the "Add Camera To Camera Group" option.
Any camera inside the group can be locked or unlocked, enabled or disabled. Initially, all newnewly added cameras are alphabeticallyordered ordered.alphabetically. It is possible to change manually this order manually by dragging the cameras in the desired position.
Camera Gizmos
LookAtVector
UPVectorUp Direction
Editing is done by click-and-drag the ring around the camera body (which is highlighted with yellow when selected,selected). as it can be seen in the image bellow), and theThe current up-vector will be rotated around the world looking-at direction, obtaining a "rolling" effect considering the Y mouse movement.
Projection
Light Gizmos
Direction
Editing is done by click-and-drag on the direction arrowarrow. and theThe direction vector will be rotated by a free rotation alt-azimuthally model, using both X and Y mouse movement.
Range
Spot Exponent
Spot Angle
Select
Translate
- "Object and Children" will move the selected object with its children.
Rotate
Scale
Editing Aids
Unselect an Item
Navigation Panel
