3D Scene Editor
Contents List
- Camera Manipulation
- Camera Sequence Editor
- Context Resource Pool
- Camera Group
- Camera Gizmos
- Light Gizmos
- Picking and Transforming Items
- Navigation Panel
See Also : 3D Editing Helpers
Camera Manipulation
- "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light.
- "Orthogonal" cameras with the subcategories Front, Rear, Top, Bottom, Left and Right: Orthogonal projection is a means of representing a three-dimensional object in two dimensions.
- Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree or Scene Editor panel.
- The scene has to contain an object of type Light to ensureqwa2proper lighting in the scene.
Camera Panning and Zooming
- Panning: Move the mouse while holding the middle mouse button down
- Zooming: Rotate the mouse wheel forward for zooming in and backward for zooming out
Camera Look-At Node
Camera Preview Thumbnail
- 100x100px for 3D cameras
- on a surface of the same aspect ratio as the render target, and then reduced to a thumbnail image - for 3D cameras
Reset Camera
- Select (in Render Targets panel) one camera associated to the respective render target;
- Press the F3 keyboard key; in this way, the (0) sequence number which is placed next to the name of the camera between round brackets will become editable;
- Choose and write the desired sequence number;
- Press the Enter key.
Camera Group
- Via "Add" > "New item" option by using the Scene Explorer context menu. Creates a Camera group in a folder specified by the user during this process.
Camera Gizmos
LookAtVector
UPVector
Projection
Light Gizmos
Direction
Range
Spot Exponent
Spot Angle
Select
Translate
- "Object and Children" will move the selected object with its children.
Rotate
Scale
Editing Aids
Unselect an Item
Navigation Panel
