3D Scene Editor
- Camera Manipulation
- Camera Sequence Editor
- Context Resource Pool
- Camera Group
- Camera Gizmos
- Light Gizmos
- Picking and Transforming Items
- Navigation Panel
See Also
3D Editing Helpers
Camera Manipulation
Camera Manipulation
- "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light.
- "Orthogonal" cameras with the subcategories Front, Rear, Top, Bottom, Left and Right: Orthogonal projection is a means of representing a three-dimensional object in two dimensions.
- Scene cameras: Further, each camera part of the scene is listed in the combo box. If a scene camera is selected, the scene is displayed from that camera's perspective. Scene cameras are created by dragging an item of type "Camera" from the Toolbox panel and dropping it into the Scene Tree or Scene Editor panel.
Note:- The scene has to contain an object of type Light to
ensure properensureqwa2proper lighting in the scene.
Note:In scene camera view, the camera properties can only be edited in the "Properties" panel.
Note:-
Camera Panning and Zooming
- Panning: Move the mouse while holding the middle mouse button down
- Zooming: Rotate the mouse wheel forward for zooming in and backward for zooming out
Note:This feature is available only for "Perspective" camera.
Note:On the Perspective Camera Scope menu, the "Selection" option should be chosen.
Camera Look-At Node
Camera Preview Thumbnail
- 100x100px for 3D cameras
- on a surface of the same aspect ratio as the render target, and then reduced to a thumbnail image - for 3D cameras
Note:The "Alpha Blend Factor" and the "Alpha Destination Blend Factor" in the Default Render Mode Configuration should be set properly. For instance, the former value could be InverseSourceAlpha and the latter value could be DestColor.
Reset Camera
Camera Group
Camera
GroupCamera group feature offers extended support for display visualization. They can be added in a camera group to allow the user to enable or disable any of them (solution with many cameras).
Camera Gizmos
Camera Gizmos
LookAtVector
UPVector
Projection
Light Gizmos
Light
GizmosFor a light object the following properties can also be edited by using gizmos, not only from the Properties panel:
Direction
Range
Spot Exponent
Spot Angle
Select
Translate
Rotate
Scale
Editing Aids
Unselect an Item
Navigation Panel
Navigation Panel
