3D Scene Editor
  • Camera Manipulation
  • Camera Sequence Editor
  • Context Resource Pool
  • Camera Group
  • Camera Gizmos
  • Light Gizmos
  • Picking and Transforming Items
  • Navigation Panel
See Also
3D Editing Helpers
Camera Manipulation
Camera Manipulation
  • "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light.
Note:
The scene has to contain an object of type Light to ensure proper lighting in the scene.
"Camera Manipulation" Toolbar Items
Note:
Perspective Camera View
Orthogonal Top View
Scene Camera View
Note:
"Aspect Ratio" Property and its Tooltip
Camera Panning and Zooming
Note:
Note:
Perspective Camera Scope Menu
Camera Look-At Node
Camera "Look-At Node" Property
Camera Preview Thumbnail
  • 100x100px for 3D cameras
Camera Preview Thumbnail in the Property Grid
Note:
Reset Camera
Reset Camera Button
Camera Group
Camera Gizmos
Light Gizmos
Navigation Panel
