3D Scene Editor
See Also : 3D Editing Helpers
Camera Manipulation
  • "Perspective" camera: It offers an approximate representation of the image as it is seen by the eye. A default light is used when the scene doesn't contain any object of type light.
The scene has to contain an object of type Light to ensureqwa2proper lighting in the scene.
Camera Panning and Zooming
Camera Look-At Node
Camera Preview Thumbnail
  • 100x100px for 3D cameras
Reset Camera
Back to the menu
Camera Sequence Editor
  • Select (in Render Targets panel) one camera associated to the respective render target;
  • Press the F3 keyboard key; in this way, the (0) sequence number which is placed next to the name of the camera between round brackets will become editable;
  • Press the Enter key.
Back to the menu
Context Resource Pool
Back to the menu
Camera Group
Back to the menu
Camera Gizmos
LookAtVector
UPVector
Projection
Back to the menu
Light Gizmos
Direction
Range
Spot Exponent
Spot Angle
Back to the menu
Select
Translate
Rotate
Scale
Editing Aids
Unselect an Item
Back to the menu
Navigation Panel
  Makes zoom out, zoom in
Back to the menu
