3D Nodes
Contents list
3D Toolbox
Create 3D Nodes
3D Nodes
1
Group: Represents a parent container for nodes or other groups. Candera::Group |
2 |
Light: Different types of light could be added to illuminate the scene objects. Read more... Candera::Light |
3 |
Camera: To be linked to a render target, where the render result of the camera will be drawn. Read more... Candera::Camera |
4 |
Reflection Camera: Creates a reflection of a specific camera on a given reflection plane. Read more... Candera::ReflectionCamera |
5 |
Stereo Camera: Creates the effect of stereo 3D. Read more... Candera::StereoCamera |
6 |
Sky Box: A type of mapping that gives the user the feeling of immersion into a large environment. Read more... Candera::SkyBox |
7 |
Billboard: A textured or colored 2D area. Candera::Billboard |
8 |
Planar Shadow: Provides the possibility to "throw" some shadows on a configurable planar surface. Read more... Candera::PlanarShadow |
9 |
MorphingMesh: A mesh that stores weight values for morphing. Read more... Candera::MorphingMesh |
10 |
LodNode: A node which accommodates multiple nodes, each of them representing a certain, predefined level of detail. Read more... Candera::LodNode |
11 |
PointSprite: Displayed as a flat square polygon which is always facing the camera (screen-aligned). It can be textured and scaled to simulate perspective. |
Canvas Nodes
12 |
Canvas: A node which acts as a surface. Read more... Candera::Canvas |
13 |
CanvasGroup: A node which can contain other canvas nodes. Read more... Candera::CanvasGroup |
14 |
CanvasSprite: A node which represents a solid object, offering the possibility to render a texture, a flat colored rectangle or other visual effects. Read more... Candera::CanvasSprite |
15 |
CanvasText: A node which facilitates displaying text on Canvas. Candera::CanvasText |
- on the Scene Tree to sort the node properly into the scene graph
- directly into the render view of the Scene Editor to create the node on a specific display coordinate.
Light
Types of Light
1 Ambient Light
2 Directional Light
3 Point Light
4 Spot Light
Light Properties
- Type: The type of a light source can be changed at any time. This might be useful for switching to a simpler lightning model. Illumination is enabled, if light has rendering enabled and if the node is in the same scope as the light.
- Ambient Color: defines the ambient color component that illuminates the ambient color component of the material.
- Diffuse Color: illuminates the diffuse color component of the material. It is ignored if type of light is Ambient.
- Specular Color: defines the specular color component that illuminates the specular color component of the material. Ignored if type of light is Ambient.
- Direction: defines the direction of the light. It is ignored if type of light is Ambient or Point.
- Range: defines the range from light to geometry in world space where illumination is applied. It is ignored if type of light is Ambient or Directional.
- Constant Attenuation Factor: defines the constant attenuation factor of the light. The attenuation equation is: 1 / (constant + (linear * distance) + (quadratic * distance^2)). It is ignored if type of light is Ambient or Directional.
- Linear Attenuation Factor: defines the linear attenuation factor of the light. It is ignored if type of light is Ambient or Directional.
- Quadratic Attenuation Factor: defines the quadratic attenuation factor of the light. It is ignored if type of light is Ambient or Directional.
- Spot Angle: defines the spot angle of the light cone in degrees. It is ignored if type of light is Ambient, Directional, or Point.
- Spot Exponent: the distribution of the light within the spot light cone. It is ignored if type of light is Ambient, Directional, or Point.
- CoordinateSpace: defines the coordinate space for lighting calculations in shader. It has two possible options:
Camera
Please refer to section Camera Manipulation for details on how to manipulate cameras.
Camera Render Strategy
Camera, Reflection camera and LeftEye/RightEye (StereoCamera) objects have a property (available in Properties panel) called "RenderStrategy" that only affects the processing of that camera and its nodes.
Per default "none" is selected as camera render strategy, which means the nodes will be rendered inside a render pass according to the defined render order.
Benchmark Render Strategy
In a render pass, only that part of the scene graph is rendered, which node's benchmarks are beyond a given threshold. In the next render call, rendering will resume at the previous stop point, until it is complete.
Two properties are relevant to achieve this behavior:
- "Render Benchmark": A render measure value of the node, given an average time required to rendered that node. Render benchmarks can be calculated by CGI Analyzer and imported into SceneComposer.
- "Benchmark Threshold": Only nodes with an accumulated node render benchmark value smaller than or equal to the given threshold will be rendered during a single render call. Otherwise rendering is paused and the remaining nodes will only be rendered in the next step.
Occlusion Culling
Occlusion culling render strategy applies only to OpenGLES 3.0 platforms.
The render strategy uses a dynamic property (QueryProperty) per node to determine if an occlusion query should be issued or not. It also stores the query result for that node in that property.
Reflection Camera
Reflection camera is a special item in the Toolbox that can be added in scenes only under camera nodes using drag & drop.
The camera will have some modified properties after adding a reflection camera on it. After the reflection camera is removed, the camera may still have some modified properties which have been previously required for the reflection camera.
The reflection will not be rendered in predefined views (Perspective, Orthogonal). Depending on the desired visual effect, set the proper values for the properties: IsColorClearEnabled and SequenceNumber.
Stereo Camera
A LeftEye camera and a RightEye camera will be assigned to the StereoCamera. The LeftEye camera and the RightEye camera may be configured from the properties panel as any other camera. The properties specific for the StereoCamera may be configured from the Properties panel that is available when the StereoCamera is selected. Those are:
- Eye Separation and
- Convergence distance
Eye separation controls the interaxial offset of the two Camera objects positions relative to the StereoCamera's position. Here for both camera's the position is set to half of the separation in +X and -X direction.
The stereo camera configuration is hardware dependent and it reflects the way in which the stereo effect is achieved in hardware. Without a special designed hardware it is not possible to properly display any stereo content. Stereo hardware most commonly provides the viewer True 3D visuals by interlacing or overlapping the two video outputs on the same display unit.
Without a special designed hardware the only possibility to check the Stereoscopy on SceneComposer is to link every Eye Camera to a different Render Target. For instance, it is possible to associate the LeftEye with a Left Render Target and the RightEye with a Right Render Target. The association of any Eye Camera should be done by following the usual two steps:
- Create a Display and two Render Targets. Read more...
- Associate every of the two cameras to one specific display (RighEye Camera to the R Render target and LeftEye Camera to the L Render target). Read more...
Both Render Targets are expected to be kept grouped under the same Display as it can be noticed in the image above.
Stereo Camera Side by Side
If a RenderTarget already includes cameras, you can not choose it. So, remove cameras in the RenderTarget and select "Camera Side-by-Side Configuration" menu to be appeared its dialog. After a display and a render target are created, select the Render Target. After this step click "OK".
In the Render Targets panel both "eyes" associated with the Stereo Camera will be displayed.
The Viewport property is automatically set. Practically speaking, all the cameras are automatically configured. The dimension of the render target is the only setting that has to be configured manually.
Sky Box
Usually you need to specify only texture to show skybox (CubeMap Texture). And you do not need to specify VertexBuffer and Shader. But if you want to specify your own SkyBoxMesh:
- If the Render Mode is used, Enable Depth Write and Enable Depth Test have to be set as "false";
- An adequate CubeMapTexture with six sides has to be set as texture;
- In Appearance the Shader Program that must be selected is RefTransCubeMap_RefCubeMapTex;
Planar Shadow
- Set the light property (the source which will generate the shadow of the object)
- To set the display it is mandatory for the render target to contain a stencil buffer (stencil bits = 8)
- Shadow plane might be configured by using the PlaneDistance and PlaneDirection properties. Please, note that the shadow is on object by itself so its color (material) or render mode can be changed.
- The default shader is adequate for the renderization process.
The AlignmentNode property exposes Candera's automatic alignment behaviour.behavior. When the alignment node is set, Candera automatically aligns the shadow plane to the alignment node (which usually is the shadow receiver).
- The shadow cannot be edited by using gizmos (translate, rotate, scale);
- The shadow bounding box is the only selection indicator;
- The correct renderization is related with a stencil buffer;
- It is not possible to add children on shadows;
- The shadow is a mesh; so, a vertex buffer can be associated. If the user will explicitly associate a vertex buffer, the shadow can render with that vertex buffer just if the "IsAutoVertexBufferEnabled" property is deactivated.
Morphing Mesh
Shape Morphing
CGI Studio supports not only a single shape being morphed into another but allows contributing multiple models to the resulting shape. The degree of contribution of a single model to the result is controlled by "morph weight" attribute of the regarding model.
Morphing of multiple models can be used for various fancy effects such as 'chaotic' vertex movement, explosion effects, and simple particle effects.
Technical Background
Vertex Position = Vertex Position 0 * Morph Weight 0 + Vertex Position 1 * Morph Weight 1;
Prerequisites
Create a MorphingMesh
To create a MorphingMesh at least one .fbx file has to be imported. Choose "Import > Import Resources..." from the menu. This will open the "Import Resources" dialog. Browse to your FBX file an click [ Open ] to import the file.
To import the FBX file in Import dialog click "Select Files..." button.
It is possible to import FBX files in SceneComposer by dragging them on "Solution Explorer" panel.
Configuring shape morphing in SceneComposer:
- Create a "MorphingMesh" in a scene by drag and drop from the 3D Toolbox.
- Drag and drop all vertex buffers having the same amount of vertices, which shall be used for morphing to the MorphingMesh.
The vertex buffers can be dragged just from the Solution Explorer to the MorphingMesh
Configure Morphing Weights
The sum of the weight of all
mophingmorphing mesh items part of a MorphingMesh must be 1.00 to get correct morphbehaviour.behavior.
By default, after creating morphing mesh items, the morph weight of the first item is set to 1.00, while morph weights for all other items are set to 0.00.
Wireframe Line Width
- The actual line width is determined by rounding the specified width to the nearest integer.
- If the setting is less than “1”, it is always set to “1”.
Morphing Shader
- RefTransLight1Morph_RefColor and
- RefTransLight1Morph_RefColorTex
support morphing between maximal 2 vertex buffers.
Level of Detail (LOD)
Create a LodNode
- Create a lod node item called "LodNode" in a scene by dragging it from the Toolbox and dropping it to the scene.
- Add children (for example: 2 Billboards) to the LodNode, providing models for each desired lod level. Note that each child node needs to have an own RenderMode attached.
Configure Lod Levels
- index,
- lower bound of visibility range and
- upper bound of visibility range.
While the index is given by the order of the LodNode children in the scene graph, lower and upper bound can be configured either in the Properties panel or in the "Configure Level of Detail" dialog. For this, use the context menu item "Configure Level of Detail" on the selected LodNode in Scene Tree panel:
First of all, the "Level of Detail" dialog allows to specify the Lower Bound and the Upper Bound for any child part of the LodNode.
The same operation can be done in the Properties panel, whenever a LodNod child is selected in the Scene Tree panel:
Configure LodNode
- LoD render strategy,
- LoD criterion and the
- preview type
The preview type property can be edited in the Level of Detail Configuration dialog, too.
Discrete LoD Render Strategy
Blend Lod Render Strategy
- Enable Depth Bias
- Opaque and Transparent Render Order Bin
Again, after choosing "DistanceToCamera" Lod criterion, the LoD level will be switched depending on the distance of the LoDNode to the camera.
Canvas
Canvas Sprite
- RefCanvasTrans_RefTex
- RefCanvasTransLight1_RefColor
- RefCanvasTransLight1_RefColorTex
- RefCanvasTransUniDiffuseMat_RefCanvasUniDiffuseMat
Canvas Text
Alignment: The text has a property for horizontal alignment. This property aligns the text within Text::Size. If no Text::Size is set, the Layout::Size is used. The layout has a horizontal and vertical layout alignment property which is used to align the ‘block’ of the measured text within the Layout::Size. The defined layout alignment can be propagated to the text alignment when the text alignment is set to ‘Auto’.
Canvas Text Outline
To use the "Canvas Text Outline" feature, it is mandatory to use an Appearance Collection that has set "RefTransColor_RefColorTexAlpha" as shader.
Canvas Layouter
The settings for this feature can be done through a category with the same name available in the Properties panel. To accesaccess it, first, a Canvas Group - included in a Canvas - has to be selected:
- BaseLine Layouter
- Grid Layouter
- Overlay Layouter
- Stack Layouter
- DockPanel Layouter
Baseline Layouter
- Select the Canvas Group holding the nodes to be layouted in the Scene Tree panel
- Choose LayoutType "Baseline" from the Properties panel
- Set any value for property Base Line Offset in the Properties panel, depending on the desired laying out
Grid Layouter
- Select the Canvas Group holding the canvas nodes to be layouted in the Scene Tree panel
- Choose LayoutType "Grid" from the Properties panel
- Optional: Set the number of rows and columns of the grid by editing the properties RowCount and ColumnCount in the Properties panel
- Use the context menu item "Configure Layouter" on the selected Group in the Scene Tree panel to open the "Grid Layout Editor" dialog
Overlay Layouter
- Choose LayoutType "Overlay" from the Properties panel
Stack Layouter
- Select the Group holding the nodes to be layouted in the Scene Tree panel
- Choose LayoutType "Stack" from the Properties panel
- Choose "Horizontal" or "Vertical" value for property Arrangement in the Properties panel, depending on the desired laying out
DockPanel Layouter
- Choose Layout Type "DockPanel" from the Properties panel
- For any canvas node inside the Canvas Group a new property will become available: "Dock Side". Select it and choose any of the fours available laying outs: "DockLeft", "DockTop", DockRight", "DockBottom".
