2D Laying Out
Laying out is a feature specific to 2D scenes. Once a layouter is applied to a 2D group, all children of that group will be affected by the given layout strategy.
If the user does not want any laying out support, thus normal editing procedure is applied and no laying out is set. If the user enables laying out for some nodes, and he does not want to move by mistake any of the child nodes which are layouted, the "strict laying out" option can be enabled from File-Preferences menu, Editor - 2D section. On-demand laying out is available by pressing CTRL+ L or by calling "Edit" > "Do-Layout" menu option to trigger Candera to layout all objects in the scene
Candera supports four built-in layouters: Stack, Grid, Baseline, Overlay, and DockPanel each layouter having some specific configuration parameters.
General Layout Properties
The following properties can be set to any node which is arranged by a parent layouter.
A layouter can only be set on a group, having some specific properties, while final laying out is determined by the properties set on all the arrangeable items that are contained in any group on which a layouter was set.
After the creation of a layouter, the borders of the grid cells - including bounding boxes - can be visualized simultaneously in the Scene editor. Actually, the border of every cell of the layouter will be visible as a yellow line.
This border is visible if the entire group is selected or if just one single cell is selected.
Two different secondary borders - the bounding box of the parent node, and the bounding box of the effective node - will be visible, marked with blue, if some values are set.
The effective bounding box will become visible if layout values - like margin of the element - are added in Properties panel.
Row, Column Number
If the parent layouter is a grid, the elements position in the grid can be changed. This has same effects like arranging a node in the Grid Editor Dialog.
Alignment
Horizontal Alignment: Each layout-able element can specify its horizontal alignment inside the area which is available by the parent layouter.
Vertical Alignment: Each layoutable element can specify its vertical alignment inside the area which is available by the parent layouter.
Size
Specify a fixed size for an element by setting the width and height. In case the element won't be asked for its preferred size.
Note: Minimum Size and Maximum Size is taken into account! If the preferred size of the element should be taken set value -1;-1.
Minimum Size: An element won't get smaller than its minimum size.
Maximum Size: An element won't get larger than its maximum size. If more space is available, it will be placed according to its alignment parameter (see above).
A fixed size can be defined by setting the same values for minimum and maximum size. (tbd: default value)
Margin
The margin for an element defines some extra space around itself. Different values can be set for left, top, right and bottom margin.
Stretch Behaviour
If the items size (size of an image, text, or colored rectangle) is smaller than the available space one of the following stretch behaviors can be set:
    None: The item will not be stretched; it will be rendered in its original size, Fill: The item will be stretched (or shrunk) to fill the exact available space. Uniform: The original aspect ratio of the item will not be changed, but all of the item will be shown. Therefore the item might not fill the whole width or height of the available space. UniformToFill: The original aspect ratio of the item will not be changed, but the whole available space will be filled. The image will be cut off on the right or bottom side, when Candera_Layout_Clipping is enabled.
    Back to the menu
    Stack Layouter
    Stack Layouter
      Select the Group holding the nodes to be layouted in the Scene Tree panel Choose LayoutType "Stack" from the Properties panel Choose "Horizontal" or "Vertical" value for property Arrangement in the Properties panel, depending on the desired laying out Call the Do-Layout command using the shortcut keys "Ctrl+L" or from the Edit - Do-Layout menu
      Back to the menu
      Grid Layouter
      Grid Layouter
      In a Grid layout, every node part of the layouted group is assigned to a cell of the grid. A Grid Layout Editor is available to configure the grid and to arrange nodes in the grid's cells by drag & drop operation.
        Select the Group holding the nodes to be layouted in the Scene Tree panel Choose LayoutType "Grid" from the Properties panel Optional: Set the number of rows and columns of the grid by editing the properties RowCount and ColumnCount in the Properties panel Use the context menu item "Configure Layouter" on the selected Group in the Scene Tree panel to open the "Grid Layout Editor" dialog
        See also:
        General
        Back Layoutto Properties
        the
        Stack Layouter
        Grid Layouter
         menu
        Baseline Layouter
        Baseline Layouter
          Select the Group holding the nodes to be layouted in the Scene Tree panel Choose LayoutType "Baseline" from the Properties panel Set any value for property Base Line Offset in the Properties panel, depending on the desired laying out Call the Do-Layout command using the shortcut keys "Ctrl+L" or from the Edit - Do-Layout menu
          See also:
          Back to the menu
          Overlay Layouter
          Overlay Layouter
            Select the Group holding the nodes to be layouted in the Scene Tree panel Choose LayoutType "Overlay" from the Properties panel Call the Do-Layout command using the shortcut keys "Ctrl+L" or from the Edit - Do-Layout menu
            See also:
            Back to the menu
            DockPanel Layouter
            DockPanel Layouter
            The "DockPanel" layout provides a layout area within it is possible to arrange child elements around the edge of the screen based on four direction: Top, Bottom, Left, and Right.
              Select the Group holding the nodes to be layouted in the Scene Tree panel Choose Layout Type "DockPanel" from the Properties panel For any node inside the Group a new property will become available: "Dock Side". Select it and choose any of the fours available laying outs: "DockLeft", "DockTop", DockRight", "DockBottom".
              See also:
              Back to the menu
