Sauna Screen
Please note that due to the display size the solution - when opened with the player - may exceed your computer screen. To adjust the size of the solution please use the "Zoom" options of the player panel.CGI Panel.
Feature Description
No Scene Name Description
(1) StartUpScene2D This initial scene displays the Candera logo and acts as the entry point to the sauna automation solution. It allows touch interaction to transition from the startup screen to the main menu interface.
(2) BackgroundScene2D This scene features a background along with a digital time representation.
(3) OptionScene2D This scene acts as the main control interface of the sauna automation solution, providing access to different sauna modes such as Sauna, Steam, Infrared, and My Sauna. Each mode is represented through an interactive tile-based layout for simplified navigation between functionalities.
In addition, the scene provides real-time environmental monitoring, where temperature and humidity values are displayed through circular indicators.
(4) SaunaScene2D
This scene handles sauna temperature control through a circular slider–based interface, allowing dynamic adjustment of the sauna environment. It also includes predefined session timing options.
In the lower mid section controls for lights (including brightness and RGB settings), ventilation and music can be found. The individual menus can be cycled through via the available navigation arrow controls or swiped through by touch control.
A preheat feature is also integrated into the interface, enabling the sauna environment to be prepared before the session starts.
(5) InfraredScene2D In addition to the features described for (4) SaunaScene2D this scene also includes panel selection options to enable the users to tailor their infrared experience to their needs.
(6) SteamScene2D In addition to the features described for (4) SaunaScene2D this scene also includes a separate circular slider for adjusting the steam level according to the users' needs.
(7) MySaunaScene2D This scene provides personalized sauna configuration management through preset-based controls. It allows selection between multiple preset profiles, enabling quick access to predefined sauna, steam and infrared settings and preferences.
The interface enables quick transition between customized sauna profiles while maintaining a clean and interactive layout.
(8) Preset1Scene2D This scene manages a predefined sauna configuration profile through dedicated controls for temperature, humidity, session timing, and ventilation management. The parameters can be modified dynamically to customize the sauna environment based on the selected preset configuration. Ventilation control and preheating functionality are also integrated to prepare the infrared environment before the session begins.
(9) Preset2Scene2D This scene is similar to Preset1Scene2D but features settings tailored more for a steam experience.
(10) Preset3Scene2D This scene manages a predefined infrared sauna configuration through dedicated controls for heating intensity, infrared panel selection, session timing, and ventilation management. The intensity level and panel combinations can be configured dynamically to customize the infrared sauna experience. Ventilation control and preheating functionality are also integrated to prepare the infrared environment before the session begins.
(11) RunningScene2D This scene provides real-time monitoring and management of the active sauna session by displaying essential operational parameters such as temperature, humidity, selected sauna mode, door status, and configured session duration. The interface presents all session-related information in a centralized layout for continuous tracking of the sauna environment during operation.
A session countdown indicator is provided to display the remaining session duration before completion. Additionally, a dedicated stop control allows immediate termination of the active sauna session whenever required.
(12) PreheatingScene2D This scene manages the sauna preheating process by monitoring and displaying the progress of the heating cycle. It provides target temperature tracking functionality, allowing the system to indicate the current progress toward the configured sauna temperature before the session begins.
A real-time countdown display is provided to show the remaining preheating duration, helping monitor the estimated time required for the sauna environment to reach the desired condition. A dedicated stop control is integrated into the interface to allow interruption or cancellation of the preheating operation whenever required.
Controls
  • The existing controls available in the Scene Composer toolbox are utilized to create this solution such as lists, sliders, radio buttons etc.
  • A customized On/Off button control is used in the Infrared scene to manage panel selections such as Top, Right, and Left. This control works similarly to a checkbox, but it is customized to display any one image. The control is customized by configuring only the required properties related to state handling, image switching.
  • An own control was created for the circular sliders in the SaunaScene2D/SteamScene2D/InfraredScene2D, that extends the existing CircularSlider control with the background image and the slider value text and unit.
Transitions
Transition rules were used with Fade-shade animations are applied to the scene transitions to create smooth and continuous visual movement between Scenes.
Animations
The following two animations are used:
  • TimeRemaining: decreases the remaining time displayed in the PreheatingScene2D
  • PreheatPulsatingAnimation: takes care of the pulsating of the red background in the BackgroundScene2D.
Both animations are started in the Statemachine when the "Start Preheat" button in the SaunaScene2D is pressed.
State Machine
Operational Control Elements
  • Forward and backward navigation buttons are implemented to control movement between different scenes and feature sections within the sauna automation solution. These controls enable smooth transitions across interfaces such as Sauna, Steam, Infrared, Presets, and operation monitoring scenes.
  • Start buttons are used to initiate functionalities such as sauna sessions and preheating operations and Stop buttons are implemented to terminate active operations and return the system to the required operational state.
  • Increment (“+”) and decrement (“−”) buttons are used to dynamically adjust operational parameters within the interface. These Buttons are applied for modifying values such as temperature, humidity and time.
  • Interactive scroll bar controls are incorporated within the interface to manage configurable features such as Lighting, Ventilation, and Music functions. These controls enable precise and fluid parameter adjustment through continuous sliding interaction, with all value changes dynamically reflected during runtime based on the configured operational ranges.
