Sauna Screen
Feature Description
| (3) | OptionScene2D | This scene acts as the main control interface of the sauna automation solution, providing access to different sauna modes such as Sauna, Steam, Infrared, and My Sauna. Each mode is represented through an interactive tile-based layout for simplified navigation between functionalities. In addition, the scene provides real-time environmental monitoring, where temperature and humidity values are displayed through circular indicators. |
| (4) | SaunaScene2D |
This scene handles sauna temperature control through a circular slider–based interface, allowing dynamic adjustment of the sauna environment. It also includes predefined session timing options. In the lower mid section controls for lights (including brightness and RGB settings), ventilation and music can be found. The individual menus can be cycled through via the available navigation arrow controls or swiped through by touch control. |
| (5) | InfraredScene2D | In addition to the features described for (4) SaunaScene2D this scene also includes panel selection options to enable the users to tailor their infrared experience to their needs. |
| (6) | SteamScene2D | This scene manages the steam sauna experience through circular control interfaces used for adjusting temperature and steam intensity levels. It provides configurable session duration options for simplified operation and includes ambience lighting controls with brightness and RGB customization features. A dedicated preheat control is provided to initialize the steam environment before the session starts. |
| (7) | MySaunaScene2D | This scene provides personalized sauna configuration management through preset-based controls. It allows selection between multiple preset profiles, enabling quick access to predefined sauna settings and preferences. The interface enables quick transition between customized sauna profiles while maintaining a clean and interactive layout. The preset controls are integrated with the overall sauna automation solution for synchronized configuration and operation management. |
| (8) | Preset1Scene2D | This scene manages a predefined sauna configuration profile through dedicated controls for temperature, humidity, session timing, and ventilation management. The parameters can be modified dynamically using increment and decrement controls to customize the sauna environment based on the selected preset configuration. Ventilation status management and preheating functionality are also integrated to help prepare the sauna environment before the session begins. |
| (9) | Preset2Scene2D | This scene controls a predefined steam sauna configuration through dedicated management sections for temperature, humidity, session timing, and ventilation settings. Each configuration parameter can be updated interactively using increment and decrement controls to maintain the desired steam sauna environment. Ventilation management and preheating support are integrated within the interface to prepare the steam environment before the session starts. |
| (11) | RunningScene2D | This scene provides real-time monitoring and management of the active sauna session by displaying essential operational parameters such as temperature, humidity, selected sauna mode, door status, and configured session duration. The interface presents all session-related information in a centralized layout for continuous tracking of the sauna environment during operation. Live operational indicators are displayed throughout the interface to reflect current sauna conditions dynamically. Temperature and humidity values are monitored in real time, while the selected sauna mode and configured session timing represent the active session configuration. Door status monitoring is integrated to provide operational awareness and safety-related feedback during the session. A session countdown indicator is provided to display the remaining session duration before completion. Additionally, a dedicated stop control allows immediate termination of the active sauna session whenever required. All monitoring and control elements are integrated with the overall sauna automation solution for synchronized session management, operational control, and real-time system monitoring. |
| (12) | PreheatingScene2D | This scene manages the sauna preheating process by monitoring and displaying the progress of the heating cycle in real time. It provides target temperature tracking functionality, allowing the system to indicate the current progress toward the configured sauna temperature before the session begins. A real-time countdown display is provided to show the remaining preheating duration, helping monitor the estimated time required for the sauna environment to reach the desired condition. A dedicated stop control is integrated into the interface to allow interruption or cancellation of the preheating operation whenever required. Dynamic visual indicators are integrated throughout the interface to represent the active heating state and operational progress. The preheating controls and monitoring components are connected with the overall sauna automation solution for synchronized temperature management, operational control, and system monitoring. |
Controls
Transitions
Example:
- OptionScene2D --> SaunaScene2D --> PreheatScene2D --> OptionScene2D: Fade-shade animation is used.
- StartUpScene2D --> OptionScene2D: Fade-Shade Animation is used.
State Machine
Operational Control Elements
