3D Getting Started Solution
This solution shows an innovative sample cluster using 2D and 3D scenes. To enjoy this sample, open it in Scene Composer, save it to your disk and press the "Generate and Play" button in the top toolbar below the menu.
The initial scene shows a 3D cluster in an innovative design with a speed gauge on the left and an RPM gauge on the right side. In the centered header it says "画面中央には、ゆっくりと回転している車の3Dモデルが表示され、その上に「Air Pressure", which is the current context. Below this text you can see a 3D car model, that is slowly turning.Pressure」と表示されています。 The tire that comes into focus during the car's movement is highlighted and its current air pressure is displayed as the car continues to turn. Necessary indicators like odometer, battery and fuel status, turn lights etc. are positioned in a clear and intuitive way.
Pressing the 'Space' key (as suggested by the text in the top right corner) switches the mode to Navigation.
You can press the 'Space' key again to return to the "Air Pressure" context.
Content
This sample solution includes
- 2D and 3D scenes
- animations
- a global State Machine
