3D Getting Started Solution
This solution representsshows an innovative sample cluster using 2D and 3D scenes. To enjoy this sample, open it in Scene Composer, save it to your disk and press the final"Generate resultand ofPlay" button in the 3Dtop tutorialtoolbar ofbelow the documentation:menu.
The tutorialinitial explains how to compose a 3D scene.
Itscene shows a 3D cluster in an innovative design with needles fora speed gauge on the left and an RPM andgauge on the right side. In the centered header it says "Air Pressure", which is the current  context. Below this text you can see a 3D car diagnosticsmodel, usethat case.is slowly turning. The tire that comes into focus during the car's movement is highlighted and its current air pressure is displayed as the car continues to turn. Necessary indicators like odometer, battery and fuel status, turn lights etc. are positioned in a clear and intuitive way.
Pressing the 'Space' key (as suggested by the text in the top right corner) switches the mode to Navigation.
Now, navigation content is displayed in the center of the cluster instead of the air pressure content from the initial scene. An animation imitates navigation through a 3D scenary, displaying turning instructions.
You can press the 'Space' key again to return to the "Air Pressure" context.
Content
This sample solution includes
    2D and 3D scenes animations a global State Machine
