State Machine
In Preferences, [ Enviroment ] > [ State Machine ] allows you to configure settings related to the display of State Machine Editor.
General
Default Colors
Default colors can be set for States and Transitions displayed in State Machine Editor. Even if you change this setting, it does not apply to States and Transitions that have already been created.
Show transition details If this option is enabled, detailed information about the Transition (e.g., conditions under which the Transition occurs) will be displayed.
Transition Connection Type This option allows you to set the line type (Polyline/Bezier/Spline) for Transition to be displayed.
本設定を変更しても、既に作成済の状態や遷移には適用されません。Your changed configurations will not be applied to States and Transitions that have already been created.
